Main > Software Forum
CPWizard v2.63 Released
TheManuel:
Great!
Thank you.
I'm now ready for this part of the project.
This project will never end...
TheShanMan:
No problem, headkaze. It's not a pressing issue.
TheManuel, you might also want to consider having CPW create bezels for you. That way you don't even have to run CPW in resident mode - it just relies on MAME to show the CP bezel.
TheManuel:
--- Quote ---TheManuel, you might also want to consider having CPW create bezels for you. That way you don't even have to run CPW in resident mode - it just relies on MAME to show the CP bezel.
Thanks.
I thought of that but given that I adjust controls every now and then and I'm already starting to fill my hard drive, I was hoping I could use the resident mode. It is also more useful because I can access other files from it as well.
From Headkaze's reply it sounds as if I should be OK.
TheManuel:
I created a CP sized at 1024x768 but I usually run my games and MaLa at 640x480.
If I want my CP Wizard layout to show up at 640x480, do I have to re-size the original layout image or is there a setting to scale down the layout to the resolution I want to run at?
I know CP Wizard will display at the desktop resolution but I have everything running at 640x480.
Thanks.
TheManuel:
Never you mind. I'm a dumbass :timebomb:.
While testing, I was switching to the desired 640x480 resolution after starting CPWizard so the app did not know the resolution had changed.
By starting CPWizard at the right resolution, it does not matter what resolution the layout is at.
