Main > Software Forum
CPWizard v2.63 Released
headkaze:
doctorhifi : Yeah this is a known problem with save states causing CPWizard to show. Hopefully I can get some time to enhance the patch to prevent this from happening.
cadmium: You must export them as Bezel format not png's. When done correctly they will export as zip files and you must place them in Mame's artwork folder.
doctorhifi:
thanks. I can live with that quirk.
Your app rocks! :applaud:
cadmium:
--- Quote from: headkaze on August 06, 2008, 03:43:15 am ---cadmium: You must export them as Bezel format not png's. When done correctly they will export as zip files and you must place them in Mame's artwork folder.
When I generate them in bezel format, most of the cp's are blank?
cadmium:
In my last export batch, using Bezel, Layout Only, 1024x768 and No on Vertical Bezels 2,144 were empty layouts. It appears once it hits a certain point it just stops generating the layouts.
If I do a preview, the layouts show up just fine, but not during the export batch.
Edit. Generating them at a smaller size (640x480) seems to get more (if not all) of them?
headkaze:
--- Quote from: cadmium on August 06, 2008, 07:37:18 pm ---In my last export batch, using Bezel, Layout Only, 1024x768 and No on Vertical Bezels 2,144 were empty layouts. It appears once it hits a certain point it just stops generating the layouts.
This problem has been reported from another user and I couldn't locate the actual cause of it. It seems to me like a memory leak or something as it does it after an amount of time. If you run it on a PC with more memory it will probably work. AFAIK The only way around it at the moment is to delete the empty ones and then run it again with the "Skip Existing" option set.
