Main > Software Forum
CPWizard v2.63 Released
Miller:
Please can somebody direct me to a decent guide thanks ;D
headkaze:
TheShanMan: I just remember you had problems applying the original bezel patch so you manually applied it. I thought there could have been a problem then. The bezel patch works okay for me. But your right about some things like save state will pause Mame. It looks like I need to update the patch so it wont show during these types of pauses.
Miller: CPWizard has help included in the software if you select the Help menu. It's not complete but should give a decent rundown on how it works. It hasn't been updated in a while though.
u_rebelscum: Thanks for your input! Looks like I'm going to have to add some code to deal with the '_' in keycodes.
Miller:
--- Quote from: headkaze on June 18, 2008, 03:26:21 am ---TheShanMan: I just remember you had problems applying the original bezel patch so you manually applied it. I thought there could have been a problem then. The bezel patch works okay for me. But your right about some things like save state will pause Mame. It looks like I need to update the patch so it wont show during these types of pauses.
Ok thanks It was just I remembered a while back someone saying they were going to write a complete guide so wanted to see if it was available first before i started.
TheShanMan:
IIRC there was a problem with the patch when you first released it, which is why I manually did it (maybe I'm remembering wrong but I know it wouldn't apply automatically). That was when I was on 0.123. I've since moved up to 0.125 and didn't have to manually apply it. So it sounds like you're not waiting on me for anything at this point, but as always, if there is anything I can try for you while I wait for a new version that hopefully helps us narrow in on the problem, I'd be glad to do it.
TheShanMan:
One other idea: you may be reluctant to hand out your source code, but I could debug my problem if you want and let you know what the problem is. I've got whichever Visual Studio I'd need. And of course I'll sign an NDA. ;)
Think of it this way: I won't bug you so much with bug reports for you to investigate if I can do the investigating myself and simply report the fix. ;D
