Main > Main Forum
Project Arcade's control panel question
Pages: << < (3/3)
javeryh:
--- Quote from: smurf on November 30, 2007, 04:54:48 pm ---Okay, I understand now. Thanks for explaining that clearer. One last question though, do you have to set up a map for every game or does mame take over?
The stick comes preloaded with various maps.  I've never made one myself.  If you use MaLa as your front-end and fatfingers's plug-in (search the software forum) the correct map will load behind the scenes for any game you choose.  The user will never know the difference.  You can go from 4-way to 8-way to diagonal 4-way (Q*bert) without ever knowing it.  The stick works seamlessly.  The only set-up is getting the plug-in to work which takes about 30 seconds - plus, fatfingers is very quick to respond to questions and stuff if you have trouble with it...
smurf:
Okay, yeah, this is defiantly the way to go. I found out that it supports 8 buttons. That pretty much means I don't have to buy I-Pac, which is nice.
polaris:
--- Quote from: smurf on December 01, 2007, 02:05:23 am ---Okay, yeah, this is defiantly the way to go. I found out that it supports 8 buttons. That pretty much means I don't have to buy I-Pac, which is nice.
i believe that it has the shift function too , giving you more button options
smurf:
--- Quote from: polaris on December 01, 2007, 10:16:00 am ---i believe that it has the shift function too , giving you more button options
Oh, wow. Really? This joystick keeps on getting better and better. The more I read about it the more I want it. You'd have to be crazy not to buy it. You get what you pay for... and more. :)
polaris:
read here
Pages: << < (3/3)
Go to full version
