Author Topic: Catalyst Control Center Too Big to Apply Changes  (Read 2310 times)
Chunce DeLeone
  • Last login:August 16, 2012, 02:58:11 pm
« on: November 28, 2007, 03:53:03 pm »
When I set my resolution to 640X432 or 480 the  Catalyst Control Center is too big for the screen and I can't see the apply button at the bottom.  Does anyone know how to get around this?
ahofle
    • Arcade Ambience Project
Re: Catalyst Control Center Too Big to Apply Changes
« Reply #1 on: November 28, 2007, 04:10:54 pm »
You can usually press tab a certain number of times to get to the apply button.  Try it on a higher resolution (or another computer) and count how many times you need to tab to get focus to the apply button and then tab that many times on the lower resolution and press the spacebar to press the button.  Alt-A might also work to press apply.
csa3d
  • Will game for food
    • Galaxian Mame Conversion
« Reply #2 on: November 28, 2007, 04:30:44 pm »
Ha!  I had that same problem.  Way to skin your GUI, ATI.  I think I recall there was a skin you could apply which was more minimal, or removed skinning all together, which make the GUI smaller.  If that doesn't work, I've used RealVNC to remote admin  at a higher resolution.  Other then that, agreed... tabs and guessing..
-csa
Havok
  • Trade Count: (+17)
« Reply #3 on: November 28, 2007, 10:28:53 pm »
Hit Alt and O together - that will click OK no matter where you are in the menu...
headkaze
  • 0x2b|~0x2b?
« Reply #4 on: November 28, 2007, 11:04:48 pm »
If you right click on a program in the taskbar and select "Move" you can then use your mouse or cursor keys to move the window around.
Chunce DeLeone
« Reply #5 on: November 29, 2007, 08:05:52 am »
You Guys are chock full of good information!! Thanks,  I've been Tab-ing and guessing for a long time now, to the point where I don't even want to start fiddleing anymore because if something goes wrong its a pain to get it back,  NOT ANYMORE, Thanks!!!!!!!!!! :cheers: :cheers: :cheers: :cheers: :cheers: :cheers:
