Main > Everything Else
Running speaker cable under carpet
<< < (5/5)
Jouster:
I've done this in two different locations.  Once in the main room of an apartment, with lots of foot traffic...and the other (more recently) in my media room.
I used my Swiss army knife to cut a very small hole in the carpet (my AV equipment wasn't hidden or right on the wall) then used metal coat hangers to feed the wire through to the next hole.  I also ran the wire under the pad...could barely feel any bump unless you knew exactly where it was already.
The holes didn't grow because they are only about an inch in size.  Oh, I also used pliers or kleins to lift the carpet and pad where I was feeding the wire to.
Jouster
Navigation
[0] Message Index
[*] Previous page
Go to full version
