Main > Everything Else
Running speaker cable under carpet
<< < (3/5) > >>
zaphod:
I second the thumbs-down on wireless surrounds.
Is there another way you can configure your HT setup that would make the surround wiring a little easier?  Or could you snake it up one corner and around the room in the corner of wall/ceiling?  Maybe throw up some molding to help hide it.
ChadTower:
Rear speakers carry such a small amount of actual sounds... I can't imagine it would be all that stressful a thing to have with a powered wireless transmitter.  A passive one would of course suck but one with a power supply could work quite well in theory for rears.
shardian:
--- Quote from: CCM on November 27, 2007, 02:13:20 pm ---My friend has wireless surround speakers and they sound horrible and they don't always work.  I would stay away from them.
Well, the question is are his stock wireless, as in they get their wireless signal straight from the receiver? Do they plug in or run off a battery? What wattage are they?
Dustin Mustangs:
I have one of those general how-to books from Home Depot and they show a technique where you pull off your baseboards and cut a channel in the drywall behind them.  Run the wires through the channel, terminate were desired, re-install base boards, and your good to go.  One downfall to this method is if you have a door along your intended route.  I guess you'd have to do the same thing but with the trim around the door.
ChadTower:
If you go that route, odds are your drywall doesn't extend completely to the floor anyway, so you may not have to cut a channel at all.  This method doesn't address getting the wire from the floor level up to the speaker, though, wherever it ends up being.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
