Main > Software Forum
LEDBlinky - Arcade LED Control software and Animation Editor - v8.2
Onslaught23:
--- Quote from: arzoo on February 03, 2023, 06:33:59 pm ---
--- Quote from: Onslaught23 on February 02, 2023, 01:44:46 pm ---When I use the simple led test I can turn it off and on but when I exit the lights just come back on
Some Ultimarc boards can store an LED configuration in the firmware; you may need to clear that (using the Ultimarc software). Or this may be related to the wiring or hardware?
You were right it was a USB issue. Now that I have a new one I went and installed the new along with me
W Led Blinky update now it only recognizes one at a time. I did the whole
Firmware ID 2 process and still not able to get both recognized. Led blinky only see one as active.
arzoo:
--- Quote from: Onslaught23 on February 14, 2023, 09:31:40 am ---You were right it was a USB issue. Now that I have a new one I went and installed the new along with me
So you have two UIO boards, one set as ID1 and the other ID2, but LEDBlinky only see's the one? Does the SimpleLEDTest app show both boards? Do you have any other Ultimarc devices connected? Email me your debug log and I'll take a look.
Onslaught23:
Hey Arzoo,
I just seen this message. I went back and installed previous LED Blinky and updated the firmware. It recognizes now. It’s it something to do with updated LED Blinky?
arzoo:
--- Quote from: Onslaught23 on February 14, 2023, 06:35:19 pm ---Hey Arzoo,
I don't see how it could be related to a recent update to LEDBlinky, nothing has changed with the UIO interface. Which version is working for you? And do you mind installing the most recent version of LEDBlinky into a temporary folder and just try the SimpleLEDTest app to see if both UIOs are recognized - that way we can determine if it's the LEDBlinky version or the firmware update.
Onslaught23:
I believe it’s the new LED Blinky. I used the old version and it worked. Same firmware for the UIO boards.
I didn’t get a chance to make the log with the updated version of LED Blinky since I just went back to the old version.
