Main > Software Forum
LEDBlinky - Arcade LED Control software and Animation Editor - v8.2
arzoo:
--- Quote from: Onslaught23 on January 28, 2023, 03:14:31 pm ---LED Blinky has been giving me issues. For the life of me been trying to figure out how to reset or turn off these two buttons that no matter what will not turn off or will go into different colors when booted. I have unplugged from the board unplugged power and everything and still no dice. Please Help or show me the way
Using the SimpleLEDTest app, can you individually control the LEDs under those two buttons? This sounds like a wiring or hardware issue.
Onslaught23:
When I use the simple led test I can turn it off and on but when I exit the lights just come back on
gbarnes27:
I am having issue getting ledblinky to work. I have a new build of coin ops arcade2 vertical build. When it starts all the light light up and even when I go into a game like 1942 it speaks the game name but fire or loop lights light up or gets spoken.
arzoo:
--- Quote from: Onslaught23 on February 02, 2023, 01:44:46 pm ---When I use the simple led test I can turn it off and on but when I exit the lights just come back on
Some Ultimarc boards can store an LED configuration in the firmware; you may need to clear that (using the Ultimarc software). Or this may be related to the wiring or hardware?
arzoo:
--- Quote from: gbarnes27 on February 03, 2023, 05:21:48 pm ---I am having issue getting ledblinky to work. I have a new build of coin ops arcade2 vertical build. When it starts all the light light up and even when I go into a game like 1942 it speaks the game name but fire or loop lights light up or gets spoken.
You can try using the LEDBlinkyTroubleshooter app to see if it can provide an answer. If not, email me the debug.zip and/or debug.log files and I'll take a look.
