Main > Everything Else
Further basement work...
ChadTower:
--- Quote from: myntik1 link=topic=73854.msg764493#msg764493 ---Chad show us some pics of your progress. I really need motivation
Not a ton to see but I did just finish all of the framing of this side of the basement for now. I'm not going to frame around the windows until spring - I'm going to replace those windows then and figure more room around them = easier getting them out.
Next up is to find a day for an electrician to come over, install a circuit on that wall, put some insulation in there, and then get my workbench and a couple vector cabs and a pin set up along it.
shardian:
Roll Call!
Where does everyone stand on their respective basement projects?
I am currently working on patching the ceiling where I had to cut for wiring and lights. I'm having to experiment with the best way to do it with doing the elast amount of work. Putting back a patch and making it blend in is no simple task on a lightly textured ceiling. I'm also prepping to level a spot in the floor on which a wall is built over the slope of the mech. room drain. I had to caulk up to the wall, and tommorrow I'm putting down the leveling goop. I've been doing one wall at a time in the bigger part of the basement with fixing and priming. Slow going, but hopefully things pick up over the next month or so.
ChadTower:
At a standstill right now while I try to find time to be there when I have an electrician come in to run the new circuit. Busy time at work + holiday + scrambling for school vacation child care = hard to get this done.
myntik1:
mine is at a standstill as well. i had to traverse the new england states during my mini vacation to find a pair of ugg boots. St. Nick should be bringing me a miter saw on Tuesday so next week I should have some progress made.
shardian:
--- Quote from: myntik1 on December 21, 2007, 04:01:01 pm ---mine is at a standstill as well. i had to traverse the new england states during my mini vacation to find a pair of ugg boots. St. Nick should be bringing me a miter saw on Tuesday so next week I should have some progress made.
So this is gonna be you huh? ;D
[youtube]http://www.youtube.com/watch?v=j70aX-5pQKo[/youtube]
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
