Main > Everything Else
Further basement work...
billf:
--- Quote from: ChadTower on November 28, 2007, 11:31:00 am ---
--- Quote from: billf on November 28, 2007, 11:27:01 am --- Moral of the story, if using adhesive (especially if using PL400) make sure you have the walls where you want them.
Good advice. Fortunately I'm doing almost all perimeter walls (against the foundation) and very little interior.
Yep, the one I decided to shorten was an interior wall.
billf:
Chad, did you seal your foundation walls with something like Drylock basement paint?
ChadTower:
Yep... Drylok is exactly what I used, then covered in styrofoam insulation sheets. No plastic since the basement was already quite dry before the Drylok.
billf:
--- Quote from: ChadTower on November 28, 2007, 11:52:36 am ---
myntik1:
I'm about to start doing my basement next month. 2 questions:
(1) Since I'm thinking about putting a pellet stove in my basement, I was thinking about going with furring strips instead of 2x4 walls. I was told not to since I wouldn't be able to put good insualtion in. One since I'll have a pellet stove, would the r factor really matter (I live in the NE)
(2) The most daunting part of the task will be mudding and sanding the walls. I was thinking about hiring this out. Is it really that time consuming to get it right?
sorry about hijacking your thread
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
