Main > Main Forum
Adding a pinball plunger
RetroBorg:
Thought you might want to check this fellows cabinet out.
http://users.bigpond.net.au/paj/images/gallery/cp.html
Xiaou2:
That poor microswitch is gona get beat to death - heh
Anyway... I think we should all write mails to the author of visual pinball to get true analog support for plungers.
You could then use either an analog joystick hack - by using a pot with a gear system... or hack a mouse to make an optical wheel system. Either would be pretty simple to make...
Also, displaying a pinball table vertically (rotate monitor)would be a great addition... as youd have a lot more screen to look at.
I emailed once... but got no responce. Maybe if a lot more people mail for these features... they might be added soon.
TheTick:
--- Quote from: RetroBorg on May 09, 2003, 06:26:57 pm ---Thought you might want to check this fellows cabinet out.
So much for trying to do something original and unique, huh?
I think I'll still be trying to mount the switch on the other end of the shaft. If that doesn't work, sure looks like that will.
kspiff:
I think it's time for an Analog+ version of PinMAME.. it's usually pretty hard to get emu authors to add these kinds of things, it seems.
Chris:
Excellent! Thank you for finding this!
--Chris
