Main > Main Forum
Ultimarc 360 Shaft Rotation
fixedpigs:
--- Quote from: csa3d on November 13, 2007, 03:35:29 pm ---
--- Quote from: jrmitch on November 13, 2007, 02:28:24 pm ---
--- Quote from: squirrellydw on November 13, 2007, 02:15:37 pm ---or you can use BLUE LOCTITE on it. Works great for me
Good idea. That's probably what I'll do when I get it into the cabinet.
Thanks guys.
Just curious.. say you do this, and down the road you need to take the ball-top off, does this now become an issue?
-csa
no...blue loctite isn't permanent...
jrmitch:
Thanks guys.
-csa
There are different grades of Loctite. Blue is made to breakaway and crumble when a decent amount of force is applied. It should stand up to the incidental rotation on the ball... hopefully ;
--- Quote from: AndyWarne on November 13, 2007, 03:40:58 pm ---Another way to do this is to wrap a small amount of plumbers teflon tape around the threads on the shaft and refit the ball.
Andy
This worked perfectly. No more ball slippage! This stick is fantastic. I highly recommend it. My only gripe is that I didn't order a second!
Thanks Guys!
fjl:
Just curious why Andy himself didn't mention the notches on the shaft that allow you to use a wrench to tighten the handle. Is it because its not unreliable? I used a wrench and got it on very tight without any help from some teflon tape or blue loctite and it didn't seem it would ever come off. Or is this method unreliable and will still loosen in time?
:dunno
