Author Topic: [US-MA] WANTED: Ms Pac cab  (Read 1047 times)
« on: November 13, 2007, 09:46:19 am »
Now that my project is feasible, I can't do it with the Pac cab I had been planning... gotta be a real Ms Pac if possible.  If anyone in the MA/RI area has a Ms Pac shell they would part with reasonably, let me know.  In this case beat artwork is best as it will be repainted in a custom Ms Pac manner.
JMB
  • Last login:July 20, 2023, 07:29:22 pm
Re: [US-MA] WANTED: Ms Pac cab
« Reply #1 on: November 13, 2007, 12:21:42 pm »
Does this mean that you will be looking to get rid of a pac-man cab?  I'm interested if so.
« Reply #2 on: November 13, 2007, 12:31:50 pm »
If I can find a suitable replacement I would not have a specific use (or any room) for my Pac shell.  I wouldn't want much for it.
shardian
« Reply #3 on: November 13, 2007, 12:52:42 pm »
I find it quite ironic that the pac cab "isn't good enough", yet you want to go thru the effort of getting a true Ms. Pac, then use a non-standard paint job on it?
« Reply #4 on: November 13, 2007, 12:57:49 pm »
I agree, mostly, and if I can't find a Ms Pac cab easily I'll just go with the Pac.
I'm not going to deviate far from standard... just swapping the pink and blue layers, probably, and maybe changing which layer the bottom ghosts reside on if they don't look good in pink.  It will turn out well if I don't eff up the stenciling.
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:March 25, 2023, 09:38:52 am
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #5 on: November 13, 2007, 05:52:59 pm »
There's a trans-gender Pac-Man cab that's been converted to a Ms.Pac on eBay here. If that's what you're thinking of doing, it doesn't look bad at all. Though the front artwork doesn't fit with the coin-door.
myntik1
  • Last login:April 26, 2021, 12:03:28 pm
  • I'm part Jerry Lee and part Jerry Lee Lewis
« Reply #6 on: November 14, 2007, 01:54:50 pm »
for 15 hundo I hope it's filled with quarters
full-time sucker for part-time pay
« Reply #7 on: November 14, 2007, 01:59:50 pm »
You're right, that's not bad at all, except the yellow T molding.  I won't be broken up if I end up using this Pac shell.
