Main > Main Forum
Any one know where I can get a cheap "wall mountable" USB HUB with alot of ports
ChadTower:
There may not actually be USB adaptors for every controller.
mrclean:
--- Quote from: ChadTower on November 08, 2007, 01:03:46 pm ---
I think your right and i know nothing about soddering but I might just need to
SavannahLion:
--- Quote from: mrclean on November 08, 2007, 12:59:45 pm ---I know but im obsessed with wanting to have all the original controllers.. I'd like to also add a SMS (Sega Master System) controller as well can't find that adaptor either
The SMS controllers should be an extension of the Atari 2600 control scheme (I've never tested the SMS). The Genesis pinout is an extension of both consoles. Depending on how the Genesis USB adapter handles the multiplexing, the Genesis adapter might work for you. Expensive though, might be better off constructing your own. To see what I mean, look at http://www.epanorama.net/documents/joystick/tvgames.html
They don't really discuss the encoding scheme, just the pinout.
unclet:
Wasn't there a company which offers the authentic controllers with USB connections already? I can not remember the name.
superbigjay:
Hello MrClean,
for your usb hub, why does it need to be wall mountable?
If you only need a usb hub to mount flush in your CP, you can consider this one
It has 4 ports on one side and 3 on the other...
External view (will need a small touch up for the finish)
Internal view
You can get them on ebay for about 5$ + 8 ship.
Jay :cheers:
