Main > Everything Else
Internet browser issue / access - Tech advice needed!
<< < (2/2)
jbox:
ditto
However I've often wondered if the cheaper modem/routers might also have slightly crappy implementations of a NAT cache too. Like a round-robin that always just assumes you aren't going to have 100+ TCP connections open simultaneously and so starts to over-write data for entries that are still being used. I only wonder this because for me it is definitely linked to number of connections not the actual data rate, because I find the problem doesn't occur very often if I restrict Azureus to < 100 connections regardless of overall speed, but it occurs repeatedly if I try to push 150+ connections on some really obscure torrents where most peers must be on dialup because they only seem to have a down/up speed of 1kbs.  :dunno
ChadTower:
Hrm.  I don't see a difference if I have 1 torrent or 15 open, but maybe the number of connections per torrent could have an effect.  I suspect it's an all or nothing thing, though - any torrents running through the gateway and they're going to slap you.  Much easier to implement.
Navigation
[0] Message Index
[*] Previous page
Go to full version
