Author Topic: perhaps daft but..( 4-way, 8 way joystick)  (Read 1362 times)
-ief-
  • Last login:January 01, 2008, 12:55:35 pm
« on: November 06, 2007, 10:59:47 am »
i was just sitting here and wondered about this.
wouldn't it be possible to get some software to just ignore the 4 extra positions of the 8 way joystick so one could easely choose 4 or 8 way on a 8 way joystick?
and if it is, am i missing something else as why it isn't being done?   :-\
Re: perhaps daft but..( 4-way, 8 way joystick)
« Reply #1 on: November 06, 2007, 11:05:20 am »
No, not possible, because the diagonals are read as combinations of Up, Down, Left, Right.
Let's say you hit a diagonal, which direction should it choose?  There's no way to know.
-ief-
« Reply #2 on: November 06, 2007, 11:16:40 am »
i'm not sure if we are on the same page here (first of, i'm talkin mame and a like), as far as i understand (knowledge is limited tho ;) ) the switches of the joystick are linked to keyboard controls, for argues sake;
up    = w
right = d
as i see it that makes w + d = diagonal upper right, or am i missing something?
if i'm right, have a 8 way joystick and want to play a 4 way game the software only needs to disregard w + d input ( and w + a, s + a and s + d )
but....perhaps this is allready happening and there is another reason why people don't like playing pac-man or donky kong with an 8 way joystick ofcoarse...
in the latter case, this is/ was a daft question  8)
edit > harum, i now see your point btw...but that was not the way i was thinking as you can see above.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: November 06, 2007, 01:59:26 pm »
FWIW, there are a few ways mame can handle the "ignore diagonals" suggestion:
A. Totally ignore when a diagonal is pressed.  Con: dead spots with different sizes depending on the joystick's characteristics.
B. Treat moving to a diagonal as a change to the other ordinal direction.  Pro: quick changes.  Con: changing "switch points".
C. Treat moving to a diagonal as a not changing from the last ordinal direction.  Con: "Slow" to change to other directions, and changing "switch points".
D. Treat diagonals as a "rotated ordinal"; such as a diagonal pretends it's the direction clockwise to it.  Pro: fixed change points.  Con: rotated so not "natural" points.
E. No nothing and let the game ROM handle it.
Mame's default is B if the game driver marks the input as a 4-way, E if as an 8-way.  C used to be doable with a now removed option (-stickykey IIRC), and now needs a hack to the source (but it was removed for IMO a Good Reason).  A & D are possible by remapping, using the ANDs and NOTs features (ask if you want quick howto).
None of the above are as good as a true 4-way joystick, or some analog joysticks (u360 good, flightstick bad).  Which is why people still want 4-way joysticks.
Robin
Knowledge is Power
-ief-
« Reply #4 on: November 14, 2007, 10:27:21 am »
litlle late but...
TNX for that answer, made me feel even more daft but nonetheless ;)
i recntly hacked a sidewinder in a topfighter snes joystick and now i know how it feels like playing 4 way games with 8 way stick, it plain s***s :)
  • Last login:Yesterday at 04:31:28 pm
« Reply #5 on: November 14, 2007, 11:00:13 am »
Everyone should just use Ultimarc 360 joysticks.  No more worrying about which type of joystick to use for a particular game.  Sure, it takes a bit to get used to the "feel" of it but once you do it works great.  I don't think I'll ever go back unless I'm building/restoring a dedicated machine or something.
