Author Topic: I Want MAME to Pause When I Press Escape  (Read 1357 times)
fjl
  • Pixels Rule!
« on: November 04, 2007, 09:14:35 pm »
An older version of MAME that I use, when I pressed Escape, the Exit menu would come out, the one that says something like Press Select to Exit but it would also Pause MAME. I can't seem to do that with these newer versions of MAME. When I press escape, the Exit menu comes out but the game continues playing. I want it to pause and have the exit menu come out. Then if I press Escape again, I want it to continue as in remove the exit menu and unpause the game.
Unless I'm truly blind and can't find that option anywhere on MAME's settings. How can I do this?  :dunno
« Last Edit: November 04, 2007, 09:16:24 pm by efjayel »
northerngames
  • Trade Count: (+18)
Re: I Want MAME to Pause When I Press Escape
« Reply #1 on: November 05, 2007, 07:49:53 am »
use a keyboard and press tab then go under the general setting's and and remap the the keys to whatever you want.
fjl
  • Pixels Rule!
« Reply #2 on: November 05, 2007, 02:35:34 pm »
Nope... the Escape/Exit menu isn't even remappable.  :dunno :banghead:
What should i do?
Goz
  • KOTA
  • Last login:September 03, 2020, 02:23:18 am
« Reply #3 on: November 05, 2007, 04:14:57 pm »
That functionality is still there in MAMEPlus
fjl
  • Pixels Rule!
« Reply #4 on: November 06, 2007, 02:25:15 am »
can you show me where cause I'm using a plus version of mame and see nothing. :'(
fjl
  • Pixels Rule!
« Reply #5 on: November 09, 2007, 02:35:53 am »
Well?  ???
Lilwolf
« Reply #6 on: November 09, 2007, 12:48:56 pm »
yes, you can change it.  Its called UI Cancel.   Remap that first... then you can remap the pause to esc (just tried it... worked fine)
fjl
  • Pixels Rule!
« Reply #7 on: November 10, 2007, 06:19:29 pm »
You're right it does work but it doesn't do the unpause thing. You have to press it like three times while the game starts agains and you have no control over it  :'(
How can I make it so it pauses and brings out the exit menu when you press escape then unpauses and removes the exit menu when you press escape again? Two things at once?
