Main > Main Forum
Installed Ultra360 now other joysticks dont work
fjl:
Well do they work again if you disconnect the U360? I'd try disconnecting and connecting the U360 and see if it truly is the U360 causing the problem. Let us know what happens.
Gehrig:
The U360's are not connected to anything just mounted. I have yet to connect them. When I do, I will only use the USB.
heffe2001:
That definitely sounds like a bad ground then. Did you ever have anything connected to them or not?
fjl:
Yeah, if the U360 is installed but not connected then its definitely not a computer or connection problem. Something got disconnected when you mounted the joystick.
Try removing the joystick and see if it starts working again. But like I said before, the problem is not the u360.
Gehrig:
Yeah.... I knew that. I should have made the title of my post different. I did finally find the disconnected wire (after I cut all the zip ties off of the wires that were bundled together). It was a wire going to the IPAC LED header. Didn't even think to check that. I bought the control panel from slikstik.. so wasn't aware that they put all the 5V joystick cables together.. and connect them on the 5V pin. It must have really been hanging there.. since I was pretty careful when moving the IPAC. At any rate... all works well now. Just wanted to say thanks to Andy from Ultimarc for helping me. Talk about customer service.. I didn't even buy the IPAC from him :)
