Main > Main Forum
Car Florescent light strip, converting to ac?
Pages: << < (2/2)
Smittydc:
actually, you can plug el-wire directly into your wall socket, but it won't be as bright, because of the frequency.
MameFan:
And don't just hack any old power transformer brick that is around 12v to run it.  Most of those bricks are around 300 miliamps.   If use too small of a one the transformer will soon burn up (fire hazzard) and stop working.  Check the heat from the transformer and on the wire.  If its warm, get one with a higher amp rating like 800 or 1.2 amps.
Plugging directly into AC... while it may work (somewhat) not the best suggestion for novices!
Pages: << < (2/2)
Go to full version
