Main > Main Forum
How can I cover gaps?
Pages: << < (4/4)
ChadTower:
If he went with mitered cuts instead of filled gaps in the joints like that, he wouldn't need to bother with an internal frame, yes?
shardian:
--- Quote from: ChadTower on October 18, 2007, 09:42:35 am ---
His picture is exaggerated to better clarify the areas he is asking about.
ChadTower:
I do understand that.  In the picture they don't even touch.  If he were building that we should just let him do it and then laugh when it fell down.
Kaytrim:
Use Bondo to fill the gaps and sand it down.  Then refill if needed with more bondo.  I used this on Dad's Bartop.  I started off with a sharp corner and then using a belt sander going the length of the board rounded it over.  Then I followed up with a random orbit sander.  See the before and after pics below.
TTFN
Kaytrim
javeryh:
--- Quote ---Use Bondo to fill the gaps and sand it down.  Then refill if needed with more bondo.  I used this on Dad's Bartop.  I started off with a sharp corner and then using a belt sander going the length of the board rounded it over.  Then I followed up with a random orbit sander.  See the before and after pics below.
TTFN
Kaytrim
And there you have it.   :cheers:
Pages: << < (4/4)
Go to full version
