Author Topic: Sound Echo in Mame32  (Read 2312 times)
IG-88
  • Last login:May 09, 2023, 08:29:46 am
« on: October 15, 2007, 09:02:37 pm »
I am looking for advice on how I can fix this issue I'm having. I got an old machine that is running mame32 v.83 and some of the games have this annoying echoing during gameplay. If I try using v75 I don't have the problem. Is that small leap in versions that much more hardware intensive that it mucks up the sound? I'd like to continue using v83 if I could. Any ideas on how to fix it?
I'm running it on an optimized version of win98se. The system specs are:
1.2ghz CPU
765mb ram
ATI 3D Rage Pro Mach64
Creative Labs CT4750
thanks
-HarumaN
ahofle
    • Arcade Ambience Project
Re: Sound Echo in Mame32
« Reply #1 on: October 16, 2007, 02:57:40 pm »
It's very likely.  Any time I've run into that echoing it's because the frame rate isn't 100%.  You can check that by pressing F11 while running the game.  If it's lower than 100%, then you need more hardware.
IG-88
« Reply #2 on: October 16, 2007, 04:00:57 pm »
Cool. Do you think a better sound card or a bigger (more mb) vid card would help? What would you recommend?
-HarumaN
ahofle
« Reply #3 on: October 16, 2007, 07:46:53 pm »
In my experience those two things help very little.  I went through this same thing a couple years ago and bought a sound card thinking the onboard sound was the problem.  It didn't help at all.  The only thing that seems to help (other than tweaking MAME) is a faster CPU.  :(  What games are choppy?  Have you tried F11 to see how close you are to 100%?
IG-88
« Reply #4 on: October 16, 2007, 08:23:41 pm »
OK. I went and checked. Knights of the round was at about 84%. I changed the frameskip to auto from 0 and it helped a little. I then bumped it up to 3 and it looks pretty good. My old eyes can't see much difference. Arabian Knights was the other one I was looking at. It was at 72%. I haven't tried any frameskip on that yet.
Now. Next question. Is that frameskip I set game independent? Or is that a "global" type setting?
-HarumaN
IG-88
« Reply #5 on: October 16, 2007, 08:52:05 pm »
Never mind that last question. I figured it out. Thanks for the advice tho. I was about to start  swappin' cards like mad.  ;)
-HarumaN
