Author Topic: Ultrastik 360 "up" direction?  (Read 3001 times)
csa3d
  • Will game for food
    • Galaxian Mame Conversion
« on: October 13, 2007, 10:19:18 pm »
So I've done some quick searching, and didn't find what I'm after; was hoping someone how's got theirs up and running can help:
With the U360's, you can basically mount them however you please.  This being said, the diamond shaped circuit board on the bottom determines the joystick's "up" directions, correct?  Assuming each edge of the diamond board are labeled NorthEast, NorthWest, SouthEast, Southwest... on one edge, there's a connection where you plug the USB cord into.  So, my question, which cardinal direction should this connector be facing in order to NOT have to remap the joystick via software?
I'm not to the point of installing the computer, or i'd test this myself.  My control panel is kinda tight and I'd like to get it set up properly so I don't have redo this step later.
Thanks again!
-csa
Donkey_Kong
    • CNC Machines
csa3d
Re: Ultrastik 360 "up" direction?
« Reply #2 on: October 13, 2007, 11:18:29 pm »
So no one has to read that confusing thread again.. I gather that this is correct:
No matter how your joy is mounted, unscrew the bottom circuit board and rotated it to look as follows, looking at joy upside down (bottom mount)
               up
right      \        /    left
           pin   usb
             down
« Last Edit: October 13, 2007, 11:22:06 pm by csa3d »
fjl
  • Pixels Rule!
« Reply #3 on: October 13, 2007, 11:56:26 pm »
I was going to take a picture but I can't find my digicam's flash card. So I'll just tell you how I figured it out. First off the top metal base is a square, well more like a rectangle. Be sure to mount it straight, not angled like a diamond. It's square in shape after all. in shape. Next is that the metal base thing is completely removeable so if you mount it, you can always unscrew the bottom part and rotate it.
Now if you really don't want to go through that, then how abou yout do what I did and simply plug the u360 into an availabe USB port and test it? Windows automatically see's it as an analog gamepad. Go into Windows Control Panel, select Game Controllers and there you are. That's how I figured it out. It's not rocket science.
« Last Edit: October 13, 2007, 11:59:37 pm by efjayel »
Donkey_Kong
    • CNC Machines
« Reply #4 on: October 14, 2007, 12:09:32 am »
               up
right      \        /    left
           pin   usb
             down
I believe that to be 100% correct in my experience as well. Nice diagram.
Edit: Except I think your left and right are mixed up.
« Last Edit: October 14, 2007, 12:15:44 am by Donkey_Kong »
fjl
  • Pixels Rule!
« Reply #5 on: October 14, 2007, 12:43:19 am »
He's doing a bottom view of the U360, so his left and right are correct.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #6 on: October 15, 2007, 01:17:17 pm »
OR.... you could just look at the text marked on the PCB which says "TOP". This goes ...err... at the top...
Andy
AaronGiles
  • Last login:May 17, 2008, 09:59:11 pm
    • Aaron's Home Page
« Reply #7 on: October 15, 2007, 03:15:15 pm »
Of course, given that it's 100% reprogrammable, "top" shouldn't really matter. You just need an easy way to rotate the layouts. ;)
csa3d
« Reply #8 on: October 15, 2007, 03:27:47 pm »
Ha.  Thanks all for the inputs.  I have rotated the board to match that diagram, as I feel that's simply easiest to do it right the first time.  To me, this was not obvious from any web documentation nor instruction information received with the shipment.  BYOAC ftw!
@ Andy:  Guess I didn't see this inscribed on the circuit board.  I'll take a closer look tonight.  Maybe some diagram on your site under the joystick info would be a nice addition for us illiterates.
@ Aaron:  Yeah.. but that's a kludge.. let's hope the video system wasn't written like that  :laugh2:
Thanks all for your help with this matter.
-csa
fjl
  • Pixels Rule!
« Reply #9 on: October 15, 2007, 04:40:42 pm »
True, it is 100% reprogrammable but it would take some file editing to do so. It's better to just insert it the correct position so you don't have to edit anything.
fatfingers
  • Last login:January 26, 2015, 10:15:43 am
  • Got UltraStiks?™
« Reply #10 on: October 15, 2007, 04:55:35 pm »
Andy
Oh Andy, you can't expect us to actually READ, can you?
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
metahacker
  • Last login:January 17, 2024, 03:09:39 am
« Reply #11 on: October 16, 2007, 03:30:22 am »
top of pic = down on joystick
