Main > Everything Else
Check this out !!!
SavannahLion:
It doesn't seem like I can control it. When I first saw it, she was spinning left, the I blinked and she was spinning right.
So I checked it out in an animator and she spins right. Looked at the site and it was left. Back to the animator and it was right. Double checked by downloading both "modes" twice.
--- Quote from: ahofle on October 12, 2007, 05:40:48 pm ---Is there a way to turn on a light in that room?
I think that's part of the illusion. With shadows on the body, the illusion probably wouldn't work.
TOK:
Man, this thing is really messing with me. I couldn't get it to do anything but clockwise for a long time...
I glanced away and back, and it looked like it had switched. Found out that I could easily control it by blocking the view of feet with my hand. When I move my hand back, it continues to spin counterclockwise for a few rotations then goes back to clockwise (without blocking it). Only way I can get it to look like like it's going counterclockwise again is to block the feet/legs.
Level42:
--- Quote from: FrizzleFried on October 12, 2007, 06:17:09 pm ---EDIT: Ah! I have now trained my mind where I can switch directions instantly...and even can see her going left then right then left then right and not turning around.
Does that mean your mind is all messed up :laugh2: :laugh2: ;) ;) ;) !!
She started counter-clockwise for me. Had to focus on something else for a bit to get her go the other way around. I can't switch "on the fly" like you though....
Now she is constantly going clockwise for me.....
If it's not cold then it must be something else :P
danny_galaga:
only clockwise for me. no matter what i do, even if i try the feet covering trick. in fact ive covered the whole body except the very top of her head and even then it definitely only 'goes' clockwise...
edit: just showed a friend online and she can instantly make it turn either way. she found that if she looked at pics, it turns clockwise, if she looks at words it goes anti clockwise which totally makes sense to me. she already has it swinging side to side, in less than a minute of having seen it. none the less, it still only turns clockwise for me!
Loki:
It changes pretty fast for me when I start reading the text next to it :)
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
