Main > Main Forum
Lightup pushbuttons/iPac?
Pages: << < (3/4) > >>
RandyT:
Heh.
Sorry, I just got nervous when StephenH said +5v would light the lamps, just not at full brightness.  I didn't want you try it to see if it was bright enough, because you'd only get one chance at it :).
Not knowing someone's skill level makes it impossible to forsee what they might try.  Just trying to save someone from a punch in the wallet :)
RandyT
paigeoliver:
The +5 V on your computer probably isn't even + 5.0 to begin with, it is probably 5.1 or 5.2. You usually have a little leeway with voltages, especially with simple things like lights.
I have measured voltages on working games before and found them off by as much as 2 volts.
M-80:
--- Quote from: RandyT on May 05, 2003, 07:34:17 pm ---Heh.
RandyT
Ah, ok. Sorry about that. Yeah, I'm pretty aware that exceeding voltage requirements is dangerous to the walet and patience. ;) Even though I've never burnt out equipment by doing something careless like that, I'm still careful. :) All I need are the testimonials of the majority of other people to convince me.
What I did before I started posting here was I did some homework on this until I hit a wall, then I started looking for a major bulletin board where I could ask some questions and share experience (and maybe get some ideas I never thought of before). If I seem a little talky or not newbie enough, it's only because I've been lurking at other boards and stuff. Nothing like diving in the deep end to learn to swim. ;)
M-80:
--- Quote from: paigeoliver on May 06, 2003, 03:40:07 am ---The +5 V on your computer probably isn't even + 5.0 to begin with, it is probably 5.1 or 5.2. You usually have a little leeway with voltages, especially with simple things like lights.
Yeah, but better to be safe than sorry and have correct voltage. I might even put together something that'll accept an AC adapter or something (once I ask if that's feasable) with a power toggle switch. Rather than go from my computer's power supply (which would require a long cord that could get caught on things if I decide to make a podium of some sort). But I'll go with the driver circuit diagram just to be on the safe side (in case the AC adapter thing isn't possible noway nohow).
BillyJack:
Doesn't Happ have LEDs "kits" that fit for their lightup pushbuttons?  Thought I saw that somewhere on their site long ago...
(Sorry, this thread is so confusing I don't remember what the original question was.)
Edit: Idunno, this comes up when you click on the LED Optional link in the lighted pushbutton page.
http://www.happcontrols.com/pushbuttons/91115700.htm
Not sure if the power reqs are too high for the ipac still...  just rambling i guess...
Edit 2: Aha!  they come in 6v form (obvious if you read the page unlike me)...  i guess the 5v would power them a little dim, huh?
BillyJack
Go to full version
