Main > Main Forum
Do you use glue on your balltops?
Pages: << < (5/5)
ChadTower:
--- Quote from: dstone on October 10, 2007, 12:22:56 am ---I was always under the impression that the Teflon tape was used to form a water-tight seal between the threads, not to hold the parts together. I think it packs the tape into the gaps in the threads to prevent leakage, so I'm not sure how that would work out. I'd say just use the Loctite, that would be the safest bet.
You're right, but it also sort of wedges the part stuck, and does hold it pretty well.
Pages: << < (5/5)
Go to full version
