Main > Everything Else
Basement finishing advice
boykster:
'nother tip...dont put the blocking in place until after you build the wall. Stick build the wall lying flat on the ground, then raise it into place. Have a helper hold the wall while you go along and install the blocking and secure the wall to the blocking.
MUCH easier than building the wall in place, or raising a wall into a snug fit.
ChadTower:
Wish I could but there isn't nearly enough floor space to do that.
Navigation
[0] Message Index
[*] Previous page
Go to full version
