Main > Everything Else
Puppy training tips
pointdablame:
--- Quote from: spacies on October 02, 2007, 05:46:34 pm ---Forget Ceaser Milan. He its nuts and his methods should not be encouraged. Positive training from the start is much easier then trying to be the dominant one after things go bad.
heh, see I knew someone would pop in saying he's nuts :laugh2:
I don't put a ton of faith in him, but I still say there's good info there if you take it on the surface. You don't have to wait until something is wrong to be seen as the dominant member of the household. If you use small portions of his training from the start, you (hopefully) would never get to the point where you'd need to be on his show with his more aggressive ways, heh.
As for the choke chain, I highly recommend it. It doesn't even "choke" the dog unless you are appying constant pressure, which you should not be doing. It's a quick tug for a corrective action, and that's it. It also teaches the pup NOT to always keep pressure on the lead since he'll feel pressure on his neck. My dog has his on all the time (even now at 7yrs old), and he likes it. It's never been a problem for us.
Navigation
[0] Message Index
[*] Previous page
Go to full version
