Main > Software Forum
MAME Compiler 64 v2.0.197
Pages: << < (20/178) > >>
rooter:
--- Quote from: headkaze on February 22, 2008, 11:32:06 am ---Okay 1.12 is Released. I added support for compiling MameUI. I've tested it here and it seems to work okay including the 64 bit version.
Thanks again man.  This pretty much solved all my problems.  Now if I can just get MALA to work with a 64bit build without major slowdown.
FhM:
Hmm though I would try this out and kept getting errors. I decided just to try and compile the 123 source with no updates to rule anything out but I get:
src/emu/sound/ay8910.c: In function 'AY8910_set_volume':
Finished!
0 Hours 27 Minutes and 55 Seconds Elapsed.
src/emu/sound/ay8910.c:589: internal compiler error: in assign_386_stack_local, at config/i386/i386.c:13482
I have deleted the source and copied it in again but no luck. Any ideas?
FhM:
Ok I figured this out. It only does it when you compile for Pentium 4 +SSE3
Dustin Mustangs:
I'm trying to get rid of the left-right nag screens on v0.104u6 (the actlabs lightgun version) and am kinda confused.  I believe by this version the -skip_disclaimer option was removed so I will need to recompile to remove these.  I also believe that this version still has hiscore support so there is no hiscore diff for me to use.  I have searched and searched and can't figure out how to handle this version which I am pretty much stuck using.  Some posts seem to hint towards me having to modify the source by hand and then recompiling but they don't seem say where and what edits are needed.  Am I on the right track here?  Is there a post that goes over these source edits??
I can't seem to figure this one out and this seemed like a beneficial place to put this question and (hopefully) answer.  Thanks for any help.
brian_hoffman:
You can find that info right here. :)
http://www.gameex.info/forums/index.php?s=&showtopic=3964&view=findpost&p=24068
Go to full version
