Main > Software Forum
MAME Compiler 64 v2.0.197
sosimple:
--- Quote from: headkaze on February 22, 2008, 11:32:06 am ---Okay 1.12 is Released. I added support for compiling MameUI. I've tested it here and it seems to work okay including the 64 bit version.
You are the best man. Thanks for adding support for compiling MameUI .
headkaze:
Make sure you extract the \winui directory to \src\osd\winui and MameUI.mak to root next to the core makefile.
Also set the "Mame UI" option in Mame Compiler.
rooter:
--- Quote from: headkaze on February 22, 2008, 09:57:43 am ---rooter: Your doing something wrong, but I don't know what. I would delete your source folder, download the source again, and try again. This time try reading the instructions first ;)
sosimple: Not sure what problem that is never heard of it. Selecting a menu item is changed to the '1' key when applying the hiscore patch. I don't compile MameUI version so I wouldn't know about that. I'll have a look at adding MameUI compiling support.
I did read the instructions. You said to download the source. There are two version of the source, both of which contain different files. Only one works. It would help if you specified which one.
It would also be great if you were doing a 64bit compile and and error -99 was reported that the compiler automatically restarted itself rather that the user having to guess if they are supposed to hit Go multiple times or not.
headkaze:
--- Quote from: rooter on February 22, 2008, 04:58:01 pm ---I did read the instructions. You said to download the source. There are two version of the source, both of which contain different files. Only one works. It would help if you specified which one.
There is only one version of the source archived in two different ways, one is a self-extracting exe, and the other a zip file you have to extract manually. Both contain the exact same files.
Comon it's not that hard to press a button a few times. Next you will want me to come over and do up your shoe laces every morning ;D
Jdurg:
--- Quote from: headkaze on February 22, 2008, 05:05:41 pm ---
Let me just say tha you rock. This weekend I will have fun restoring the coin door/mechs that I bought, then compiling my own version of MAMEUI64 on my new laptop. This will be fun. :cheers:
