Main > Software Forum
MAME Compiler 64 v2.0.197
Pages: << < (13/178) > >>
Jdurg:
--- Quote from: headkaze on February 12, 2008, 01:44:07 am ---
--- Quote from: Jdurg on February 11, 2008, 08:47:07 am ---Sweet!  So is this all we need to compile MAME64, or are there other items needed in order to get it to compile?  I had been hearing that only the MS SDK was able to compile the 64-bit version so I'm a bit confused.   ;D
Yes it includes a cutdown version of the Platform SDK so you don't need to download any additional files.
Fantastic.  Thank you so much for this!   :applaud: :cheers:
bent98:
This is probably a dumb question, but in order to compile a 64 bit version of mame you need to run 64 bit OS?
Jdurg:
--- Quote from: bent98 on February 14, 2008, 07:26:59 am ---This is probably a dumb question, but in order to compile a 64 bit version of mame you need to run 64 bit OS?
Yes.  You MUST be on a 64-bit OS to compile the 64-bit version.
TheShanMan:
Just a suggestion. How about notifying the user that it's going to install stuff at C:\MinGW, hopefully with an option to change it. Otherwise, love the concept and thanks so much for the effort! :cheers:
rooter:
Dear headkaze,
Thank you so much for this!  I love you.
If I had a womb in which to make babies with, I would build you some, and they would be delicious.  For now I offer my sincerest gratitude and best wishes.
Word to your mother,
    rooter
Go to full version
