Main > Software Forum
MAME Compiler 64 v2.0.197
Le Chuck:
From wiki:
A compiler is a computer program (or set of programs) that transforms source code written in a programming language (the source language) into another computer language (the target language, often having a binary form known as object code). The most common reason for wanting to transform source code is to create an executable program.
In this case many folks want MAME to do some very specific things that it doesn't do "out of the box" so they alter the MAME source code to allow high score data, or no nag screens (two very common examples) and then put that through a compilier to get the MAME executable.
milhouse:
I'm getting an error I haven't seen with .145 with Mame Compiler 64 1.23.
Compiling Mame...
Using Parameters OSD=windows TARGETOS=win32
make: *** makefile: Bad file descriptor. Stop.
Finished!
0 Hours 0 Minutes and 0 Seconds Elapsed.
I applied 145u1, 145u2, 145u3 and hi_145u1.diff in that order bu that's the error I get...
***********NEVERMIND***********
Had to apply 145u1, hi_145u1.diff 145u2, and 145u3 in that order.
milhouse:
Though I thought I had it working, it seems something went wrong when I try to upgrade from .141 to .145u3 (relevant roms have also been updated FWIW).
I used 145u1, 145u2, 145u3 and hi_145u1.diff but though it works and everything loads, I have a few issues:
* I now get an exit prompt when I try to exit Mame (Are you sure you want to quit? Press ''UI Select'' (default: Enter) to quit. Press ''UI Cancel'' (default: Esc) to return to emulation). Looks like its from emu/ui.c.
* My old hi scores are gone for certain games (Robotron, Q-Bert) but remain for others (Ms. Pac-Man, Pac-Man).
* My old controlled config files, at least for qbert, don't work.
I've tried applying hi_145u1.diff after u1 and u3, but it doesn't seem to make a difference.
Anyone seen this before?
Flake:
I have no idea what I'm doing wrong....trying to compile mame .145 64 bit version with UI.
I get the following error:
Using Parameters OSD=winui TARGETOS=win32 -j3 ARCHOPTS=-march=native PTR64=1
make: *** No targets specified and no makefile found. Stop.
Finished!
Also, does anyone know where to get a 64bit version of mame .124. The mamedev sit doesnt seem to have this?
Flake:
Finished!
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
