Author Topic: Project Arcade Book  (Read 1042 times)
deadpool18
  • Last login:February 03, 2019, 04:22:48 pm
Project Arcade Book
« on: September 29, 2007, 08:58:11 am »
Since I'm such a newbie, I decided to order the Project Arcade Book from Amazon.com.   :)
Hopefully the book will help me figure out how to wire a control panel and solder!
Anyway, wish me luck!
Xam
  • Last login:July 18, 2011, 11:16:45 pm
  • " Oh my heavens; good gracious. Cro-Magnons."
Re: Project Arcade Book
« Reply #1 on: September 29, 2007, 10:10:00 am »
The book is very helpful. Some of the info will be a bit dated as new products have been developed since publication, but it will help you gain an overall understanding.
Xam
Can't talk to a psycho like a normal human being.
deadpool18
« Reply #2 on: September 29, 2007, 10:18:32 am »
Sounds good! I'm mainly concerned with using a router and wiring.  Everything else I think I can figure out.  :P
Lakersfan
  • Last login:February 05, 2024, 12:16:07 am
« Reply #3 on: September 29, 2007, 01:31:19 pm »
Trust me, you'll be fine as long as this site's around. Just about every "situation" is covered here. Either that or there's a ton of people waiting to answer your questions or point you in the right direction. It's a great community!!
Good luck!!
Xam
« Reply #4 on: September 29, 2007, 11:16:25 pm »
I was a bit hesitant with a router at first too...just get some scrap wood, take your time, and soon you will be comfortable using it. It was not nearly as hard to use as I thought it would be. Just don't get too comfortable as I did...made a couple of boo-boos because I thought I was better than I was... :laugh2:
Wiring is really easy. The book should help a bunch there.
Xam
GAtekwriter
  • Last login:July 16, 2011, 09:55:44 am
« Reply #5 on: September 30, 2007, 06:51:20 pm »
Don't forget to buy the arbor... !
I went to Lowe's and got the slot cutter for my router but didn't realize (learn something new everyday) that it required a special insert to hold it called an arbor.  Well, now I own one.
www.sisjarcade.blogspot.com
Jim
