Author Topic: Trackball Clicking  (Read 1532 times)
XyloSesame
  • Last login:June 11, 2020, 11:08:24 am
  • the creepy prince guy...
    • The Nightingale Theater
Trackball Clicking
« on: September 27, 2007, 12:23:54 pm »
Oy, finally got a mock-up done for my CP. Oddly enough, I had a 28" box sitting in my basement - exactly the width of my final drawing...
Now that the primary controls are in cardboard, I've noticed that the Happ 3" trackball clicks when rolled forward. I don't have anything wired, so I can't check its tracking. Doing a search, all I could find was a post from '05 that had mixed opinions...
The ball seems to roll smooth, but it sounds almost like the encoder wheel is clicking. Doesn't really bother me, but is this a normal sound for a TB?
Kaytrim
  • I'm too nice a guy
Re: Trackball Clicking
« Reply #1 on: September 27, 2007, 12:40:45 pm »
if this was a new trackball I'd get my money back.  if not then crack that puppy open and check the encoder wheel.  Post pics so we can help you out here.
TTFN
Kaytrim
XyloSesame
« Reply #2 on: September 27, 2007, 12:45:41 pm »
TTFN
Kaytrim
Not new, but from trusted source. I'll try to get time to break her open tonight, post pics, and follow some advice from the '05 thread...
  • Last login:December 13, 2023, 12:03:14 am
« Reply #3 on: September 27, 2007, 09:02:00 pm »
Check to make sure one of the encoder wheels is not touching the optics.
I had this to happen on a trackball I bought off ebay. had to carefully bend one of the optos back away from the wheel.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #4 on: September 27, 2007, 11:34:40 pm »
I was going to suggest this, or possibly something stuck to one of the rollers.  Bad bearing is also a possibility.
« Reply #5 on: September 28, 2007, 06:32:16 am »
Good suggestions too.
It will be interesting to see what he finds..
SirPeale
  • Green Mountain Man
« Reply #6 on: September 28, 2007, 07:31:46 am »
I'd definitely crack it open, esp. if used.  If it was new I'd return it in a heartbeat.
Soak the bearings in solvent, then dry them.  Use 3-in-1 oil to lube them.  Get a drill and spin them at high speed to break up anything inside.
If the rollers are too worn down, instead of what I suggested above get yourself a rebuild kit.  Comes with new rollers and bearings.
XyloSesame
« Reply #7 on: September 28, 2007, 11:18:20 am »
... get yourself a rebuild kit.  Comes with new rollers and bearings.
Thanks for the tips, everyone. The trackball was used, but was sold as a refurb with new rollers and bearings. I'd assume, from the seller's rep, that the bearings and rollers wouldn't be my problem, but I'll be checking everything just to make sure.
I hope to get into the trackball guts this weekend; however, between the 9-5, family life, and my main hobby, time is slim. When I can eek out a minute to look inside, I'll post my findings (and probably have more questions).
XyloSesame
« Reply #8 on: October 01, 2007, 10:02:17 am »
So I was able to open her up last night and here's what I found.
Nothing out of the ordinary, just a plain-old trackball. Slight ball-lines on the rollers, a very small bit of rust. Solid bearings with good seats on the shaft, no encoder rub.
I manually spun the rollers and could hear the clicking, then noticed that both encoder wheels were slightly off-center, one worse than the other. Neither appeared warped or bent, but they were both noticeably off. So I took everything apart and put it back together; now I only hear a whirring from the (still) off-center encoders. I have no idea what I did, but it seems to be better...
There seemed to be little-to-no play in the encoder wheels' attachment to the roller; is it normal to have slightly off-center wheels?
Kremmit
  • - AHOTW -
« Reply #9 on: October 01, 2007, 02:23:29 pm »
Yeah, the quality control on those little plastic encoder wheels seems to be pretty sloppy.  I've seen plenty of them that were bent so they wobbled back and forth as they spun, or the hole was a little off-center.  As long as the holes keep passing through the optics without rubbing, it really doesn't matter.
XyloSesame
« Reply #10 on: October 01, 2007, 02:57:42 pm »
Yup, definitely not a precision instrument. The encoder wheel holes are just slightly off, enough to create both a wobble and noise.
That's what I was hoping... I figure if it gets too bad or affects gameplay, I'll just buy (or make) new encoder wheels.
Kremmit
  • - AHOTW -
« Reply #11 on: October 01, 2007, 06:00:49 pm »
Quote from: XyloSesame link=topic=71785.msg739659#msg739659
If it comes to that,  I'm a big fan of these.    Put a set in my Happ ball, and wouldn't ever go back.
XyloSesame
« Reply #12 on: October 01, 2007, 06:14:47 pm »
I've seen those - GGG only lists them for Betson...
I assume, then, they'll work for Happ as well?
Kremmit
  • - AHOTW -
« Reply #13 on: October 02, 2007, 02:07:00 am »
XyloSesame
« Reply #14 on: October 02, 2007, 10:05:29 am »
I take it they will...  ;)
