Main > Main Forum
Improper ground loop causing problems?
Pages: << < (2/2)
BobA:
Ok sounds like your ground loop will function as wired.  Probably not the cause of your flakey operation.
Looking at your previous messages it look like you have alot going on.  You might want to systematically eliminate some of the problems by starting from scratch and test things as they are installed.
1. Do a clean install of windows and make sure you have only the drivers that you want.
2. Check with a keyboard only to determine if you have an IPAC problem or other problem.  Contact Andy if an IPAC problem is indicated.
3.Run MAME via command line to make sure things work.
4. Install your frontend and see what occurs.
BobA
Pages: << < (2/2)
Go to full version
