Main > Main Forum
seeking cocktail control panel advice
Pages: << < (2/2)
turbo6:
Well, i worked at a factory for 16 years polishing stainless steel for kitchen sinks etc...
I would use 180 - 220 grit sandpaper. Maybe even 280 grit, depending how much of a "brushed" look you are seeking (lower grit equals higher "brush" look). Make sure you go with the grain of the stainless steel when sanding and don't rub the sandpaper back and forth... sand in one direction only as uniform as possible if done by hand.
I hope this helps... Good luck!
Major Rock Hardy:
Thanks for the info Turbo6!
turbo6:
No problem. Let us know how things turn out... would like to see some pics when this project is completed.
danny_galaga:
well, impressed with your panel. cant wait to see how the whole thing turns out (",)
Major Rock Hardy:
--- Quote from: danny_galaga on October 13, 2007, 10:01:33 am ---
hey, thanks for the kind words... here's a pic of the test rig I built using the steel cp, 49-way, 6 leaf buttons, and my homemade spinner
it feels pretty nice, but I think I'd still like to have a bit more free space at the bottom to rest my wrist on.  I think I can still accomplish this with a 12" dimension of metal by reducing the height of the vertical (front edge) part.
Now back to playing Tempest.  More testing!
Pages: << < (2/2)
Go to full version
