Main > Everything Else
After 3 years I finally got my first dent...
shardian:
--- Quote from: ChadTower on October 22, 2007, 11:22:16 am ---
I'm pretty sure I've had the thermostat replaced in the past... if it's the same thermostat that controls engine temp.
The thermostat opens and closes to control the flow of coolant based on a set temperature. If your thermostat is stuck open, the coolant never reaches full temperature and your heater wouldn't blow hot air.
ChadTower:
Hrm. Odds are I won't look into it as I plan on replacing the car in the Spring with a pickup anyway.
mccoy178:
--- Quote from: ChadTower on October 22, 2007, 11:41:32 am ---
Careful, those trucks haul things. I don't want to see your life get more confusing than it already is.
mr.Curmudgeon:
--- Quote from: ChadTower on October 22, 2007, 11:41:32 am ---Hrm. Odds are I won't look into it as I plan on replacing the car in the Spring with a pickup anyway.
You sure blow enough hot air around here to keep things nice and toasty. This thread alone has enough wasted energy to stave off an ice age.
If only there was some way to harness that power! 8)
Stingray:
--- Quote from: shardian on October 22, 2007, 09:21:15 am ---usually it is pretty obvious the heater core is busted. Your floor boards being covered in antifreeze is a pretty good sign, you know.
Could also be clogged, which would cause it to not work, but not leak either.
-S
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
