Main > Main Forum
Need Advice:Refinishing coin door
Pages: << < (2/2)
CM:
Certainly no expert, but I simply dremel'd away the old paint with a steel brush attachment to the metal and painted it with the hammered rustoleum.   Since the paint itself is textured I did not really have to concern myself with scratches   ;)
SirPeale:
--- Quote from: Cue-Ball on May 02, 2003, 08:26:42 pm ---So, depending on the starting condition of your coin doors, you might not need to sand them at all.
It does indeed depend on the door.  The door I'm curently working on had the paint peeling of 40% of it.  Why?  The rust blooming underneath.  I used paint remover to get most of the paint off, then I'm going to use a paint remover wheel to get most of the rest off.  I have taken most of the dents out with a pair of plyers, and now I have to do nothing but wait to save enough $$$ to get it (and my other door) coated.
It's not terribly expensive, but it is when the only person in your household working is your wife.
Pages: << < (2/2)
Go to full version
