Author Topic: Making your own dust washer out of plexiglass?  (Read 11508 times)
  • Last login:Yesterday at 07:54:28 pm
« on: September 18, 2007, 12:32:58 pm »
Does anyone have any tips on how to do this?  I'm thinking of replacing the cheap black plastic dust washer that goes around the shaft of the joystick with one made out of plexiglass.  I want to paint the bottom of the plexiglass pink and then attach a thin layer of felt or something so it won't scratch the surface.  I know a few people have done this... any tips?  I'm especially curious as to:
1.  How to cut out a perfect circle (roughly 2.5" in diameter);
2.  How to polish the edge of the plexiglass once cut;
3.  What type of paint to use (I assume any type is fine)
steveh
  • Last login:January 29, 2024, 09:33:42 am
    • thecrazysteve.com
Re: Making your own dust washer out of plexiglass?
« Reply #1 on: September 18, 2007, 12:45:39 pm »
i have never done it before, but i would guess if you used a circular drill bit, like what you would use to cut a hole in a door for a door knob.  that should work great to do it.   not only would it be a perfect circle, but it would also have a centered hole in the middle.  you would just need to re-drill it big enough for the joystick shaft to fit threw.
someone please correct me if i am wrong
AcidArmitage
  • Last login:February 21, 2015, 02:19:05 am
  • keeeyaaaii
« Reply #2 on: September 18, 2007, 12:46:24 pm »
you could try a hole saw... the drill bit in the middle of it wouldn't matter because it needs a hole in the middle anyway
Senator
  • Last login:June 10, 2008, 10:25:46 am
« Reply #3 on: September 18, 2007, 01:33:38 pm »
Not to mess with your game plan but one of the best tips I read on this board, I think it was a LeapinLew thing, is that the dust washer should really be BELOW the CPO.  I got a Golden Tee overlay off of eBay, its made of a real nice plastic/vinyl kind of deal.  I routed out an area of the control panel around my joystick hole for the washer, then put my CPO and plexi over that.  Turned out real nice.  You could do the same thing with your custom washers.  I'll get some pics up once I figure out how to shrink them to a reasonble size.
BTW, I agree with the hole saw idea, get the doorknob size or even smaller, run it in reverse with light pressure, it should work perfectly.
AcidArmitage
  • keeeyaaaii
« Reply #4 on: September 18, 2007, 01:36:16 pm »
i disagree with the dust washer on the bottom because i remember one tekken cab that had one dust washer missing... I was playing it and the joystick shaft pinched the ---steaming pile of meadow muffin--- out of my hand in the hole. hated that damn machine ever since
steveh
    • thecrazysteve.com
« Reply #5 on: September 18, 2007, 01:38:45 pm »
I have to agree.  I dont understand what they would do underneath.  every game i have ever seen had them on top, and if they are not there, what covers up that ugly hole?
SavannahLion
« Reply #6 on: September 18, 2007, 01:56:48 pm »
Sand with gradually finer papers until you can polish with a polishing compound then with cloth (no compound). Google for fish tank assembly on how this is done. Another way it can be done is to use a blow torch or another controllable heat source such as those described on this woodweb thread. Whatever you do do not attempt to use power tools (except maybe a hand dremel) to speed up the polishing process. With such a small piece, you'll likely take off more than the acrylic.
You have to be careful. Some paints attack acrylic and cause crazing or orange peeling. this artist uses, what else, acrylic paints to paint on acrylic. Other paints will require primer against the plexi to prevent damage.
ahofle
    • Arcade Ambience Project
« Reply #7 on: September 18, 2007, 03:34:29 pm »
Not to mention it just creates a little well for the dust to collect.  I thought the idea was to prevent crap from getting down in there.
DaveMMR
    • TeeVee Games
« Reply #8 on: September 18, 2007, 03:46:15 pm »
Dust washers technically belong below the CPO, but that's much easier accomplished with metal panels than with wood panels.  No one bats an eye if they're on top (and some prefer it that way - including arcade operators).  I prefer it on top too just because I'm getting way too lazy to route out any more wood.
« Reply #9 on: September 18, 2007, 04:06:05 pm »
I'm looking to do what mountain did with his cabinet except mine will be pink instead of black.
RandyT
  • Last login:Yesterday at 11:46:17 am
    • GroovyGameGear.com
« Reply #10 on: September 18, 2007, 04:38:39 pm »
I've been experimenting with the new laser cutter and can do them out of ~.080" clear plexi (acrylic.)   If you just want to purchase a couple, email me.
If there's interest., I'll put them on the store as well.
RandyT
spacies
« Reply #11 on: September 18, 2007, 04:52:37 pm »
Buy some from Randy and then apply some pink signwriters vinyl.
« Last Edit: September 18, 2007, 05:23:18 pm by spacies »
  • Last login:Yesterday at 08:24:26 am
« Reply #12 on: September 18, 2007, 04:58:47 pm »
RandyT
can you cut me a piece of plexi to cover my control panel, heh
Ive broke like 9 pieces already
RandyT
« Reply #13 on: September 18, 2007, 05:15:57 pm »
Sorry, the work area isn't large enough for a whole overlay.
RandyT
xmenxmen
  • Last login:September 16, 2012, 03:05:35 pm
« Reply #14 on: September 18, 2007, 05:59:27 pm »
U might want to consider using a router to do your cutting on the plexi if you are referring cutting plexi and having them break on you using other method.  The router will melt the plexi, making it quite tough to actually break it.
« Reply #15 on: September 18, 2007, 06:10:17 pm »
RandyT
Thanks Randy.  I'm interested but I need to measure the size of the dustwasher on my CP when I get home from work.  Best guess is around 2.5" in diameter.  Depending on the cost I'd probably order 10 or so for future use...   :cheers:
mountain
  • Trade Count: (+9)
  • Last login:March 26, 2024, 11:42:28 am
    • Mountain Jukeboxes
« Reply #16 on: September 18, 2007, 06:47:04 pm »
javeryh,
I would definitly use Randy's services. I had mine laser cut and they are perfect. You might still need to polish the edges, but thats pretty simple. I started off withh 600 grit sandpaper and went up to 1500 grit. After that I used the Novus three step polish. I really like the look of it because it goes well with all of the other shiny goodness on the CP  :)
Good luck!
NoOne=NBA=
« Reply #17 on: September 19, 2007, 12:03:11 am »
You've never seen any classic arcade cabinets?
How about an NFL Blitz cabinet?
They ALL had the dustwashers under the CP.
It wasn't until people started mutilating cabinets to convert them that the dustwashers started ending up on top of the CP.
On a properly done CP, the dustwasher sits just below the top layer of the panel.
« Reply #18 on: September 19, 2007, 12:07:41 am »
Lewis is a nice guy and everything, but this advise is flat out wrong.  The joystick is going to bind and you're gonna pinch yourself.
Wasn't me. All my dust washers are on top. Unless you like the idea of dust washers under the CP - then it was me. But if you don't like your dust washers on top, it wasn't me. Either way, I win.
Senator
« Reply #19 on: September 19, 2007, 09:14:18 am »
Lew, I thought it was a great idea, soon after I saw it I was in an arcade looking at a Ms Pacman.  Sure enough, there was the dust washer under the CPO.  Made perfect sense.  I think it worked out great on my CP, very happy with it.  Thanks for sharing.
And for those that think its a bad idea:
Sorry about that Lew, I was just trying to give credit rather than presenting as my own idea.  Wasn't really aware of the downsides discussed above (I don't really think they are downsides but oh well, I'm a noob).  Thought it was you but I guess not and I can't find the old thread now.  It wasn't Lew really, he's much smarter than that.
Dudeman
  • Last login:December 30, 2023, 06:30:25 pm
  • Ecky ecky ecky ecky P'Tang! Zoop-boing mmmzoesm...
« Reply #20 on: September 19, 2007, 11:07:00 am »
You could get a circle cutting jig for your router, and cut them with that.
http://www.woodcraft.com/family.aspx?familyid=3582&productid=143735
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
« Reply #21 on: September 19, 2007, 01:20:29 pm »
I always figured they were meant to go below. The Happ sticks even have an indentation clear around the top for the washer to move around in when the stick is bolted to the bottom of the panel.
As far as the dust going in... Where is it going to go, the extra quarter inch until it hits the washer at the bottom of the panel instead of on top?
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #22 on: September 19, 2007, 01:28:29 pm »
Dustwashers are supposed to go under a metal panel. Just look at the artwork. Dustwashers on top completely messes up the way the art looks on the classic CPO's.
« Reply #23 on: September 19, 2007, 03:23:53 pm »
Doesn't the hole around the shaft look ugly if they are bottom mounted?  OMG that was the dirtiest thing I've ever typed.
ahofle
« Reply #24 on: September 19, 2007, 03:26:36 pm »
I was referring to wood control panels which is what I would assume the majority of MAME cabinet builders around here use.  That would leave a 3/4" hole for crap to collect if you put the washer underneath.  I agree that metal CPs are not an issue.
ids
  • Last login:April 16, 2023, 05:43:28 pm
  • Fighter Captured
« Reply #25 on: September 19, 2007, 03:52:29 pm »
tsk tsk... and i thought this was a family friendly forum
TOK
« Reply #26 on: September 19, 2007, 04:00:41 pm »
I have a wood panel with the top routed for the stick base. The washer sits on the stick base below the plexi overlay. There is a hole for the stick to move, but there isn't really a hole for crap to collect since it's only the thickness of the plexi.
If people are bottom mounting sticks in 5/8" wood with just half the stick poking out of the hole, I could see that being unsightly, but in that case the dust washer is just hiding an ugly install. Thats not meant as an insult to anyone, I did that in my first two panels before getting a router.
ahofle
« Reply #27 on: September 19, 2007, 04:16:06 pm »
Ugly?  Bottom mounting is cleaner IMO and you don't have to weaken the wood by routing almost half of it out.  Also why do you suppose joysticks come adjustable for metal or wooden control panels if they are supposed to be top mounted?
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #28 on: September 19, 2007, 04:29:49 pm »
I think he bottom mounted the sticks, but routed out a thin layer on top for the dustwasher
NoOne=NBA=
« Reply #29 on: September 19, 2007, 07:13:06 pm »
8 way classics, it was on top.
Dustwashers, like plexi over the CP, didn't show up until the "lets slap this crappy game into a classic cab" era.
All the dedicated classics had the dustwashers below the panel.
Here's a quick list off the top of my head:
1942, 1943, Berzerk, Bosconian, Circus Charlie, Cloak & Dagger, Crazy Climber, Discs of Tron, Gauntlet, Gunsmoke, Gyruss, Jump Bug, Jungle Hunt, Kangaroo, Rampage, Robotron, Scramble, Smash TV, Street Fighter, Super Cobra, Super Zaxxon, Time Pilot, Time Pilot '84, Tron, Up 'n Down, Vanguard, Venture, Xenophobe, Xevious, Xybots and Zaxxon.
Even the Neo-Geo, PlayChoice, and .vs cabinets shipped with them underneath.
I'm sure I missed alot that also had them on the bottom, but I'd like to see a list of classic games that had them on the top.
Some of the ones that I included I don't really consider as classics (notably Street Fighter and the multigame systems I listed).
« Last Edit: September 19, 2007, 07:16:27 pm by NoOne=NBA= »
AcidArmitage
  • keeeyaaaii
« Reply #30 on: September 20, 2007, 05:13:48 pm »
they used to make paint with lead... still doesn't mean its a good idea  :dunno
DaveMMR
    • TeeVee Games
« Reply #31 on: September 20, 2007, 06:26:10 pm »
Yeah, but it was a lot tastier!
Xiaou2
  • NOM NOM NOM
« Reply #32 on: September 20, 2007, 09:14:59 pm »
I was an Arcade manager.
 Nearly every one of the games had the dust washers on top.
 And, there is good reason...
 Try tipping a cup filled with soda all over the control panel.
 A Dust washer on top, will resist and divert more of the Liquid
away from the hole.    Keeping the joystick and micros safe
from a sticky mess.    Not to mention how much of a pain it
would be to take off the plexi to clean underneath it.
 And then you will hear people say..  well,  classics didnt have plexi...
 Yeah, and when the classics overlays started to crack,  it
made sharp edges and felt uncomfortable on the hands.  People
would then rip off the sharp parts.  Later, the other ends would get
loose and get sharp again.   Repeat this until nearly half the
overlay was ripped off completely.
 Plexi on top, and Dust washers on top..  provide greater protection
to artwork, and reduce problematic events such as spills, cracking,
and ground in dirt.
 Its not about what is 'classic'.. but what is more desirable.
 Its pure OPINION.
 (even for those who actually designed the things in the first place)
« Last Edit: September 20, 2007, 09:16:44 pm by Xiaou2 »
RandyT
« Reply #33 on: September 20, 2007, 09:39:04 pm »
So it's settled.  All of you who will be dumping soda and crap all over the control panel in your living room, make sure the dust washer is on top.  Everyone else put in underneath where it's supposed to be.
(sez RandyT, who has his dust washers on top because he's lazy ;) )
ahofle
« Reply #34 on: September 20, 2007, 09:49:33 pm »
 :laugh2:
Xiaou2
  • NOM NOM NOM
« Reply #35 on: September 20, 2007, 10:09:20 pm »
The point was that Arcade put them on top for that reason.
 Weather or not they were designed to be on top or not is
purely OPINION of the designer.   Not 'Where its supposed to be".
 You shove them up your Butt for all I care.
gurnie
  • Last login:May 10, 2013, 04:41:06 pm
  • I has the arcade in my hands. My precious...
    • Gurnie's wood working :D
« Reply #36 on: September 20, 2007, 10:16:27 pm »
Not sure if you have already bought supplies, but have you considered lexan?  I just finished building a 3 gallon aquarium (MacAquarium actually) and found the lexan was pretty easy to cut (with a utility knife over and over and over) and was not brittle like plexi (doesn't splinter like plexi can).
Please visit my Etsy website, full of my awesome woodworking
http://www.etsy.com/shop/cgurnham
mountain
  • Trade Count: (+9)
« Reply #37 on: September 20, 2007, 10:37:42 pm »
sez RandyT, who has his dust washers on top because he's lazy ;) )[/color]
***Novagem Dust Covers made with 100% Lexan ***
...hmm
« Last Edit: September 20, 2007, 10:50:58 pm by mountain »
NoOne=NBA=
« Reply #38 on: September 20, 2007, 10:55:42 pm »
Weather or not they were designed to be on top or not is purely OPINION of the designer.
The point I was making is that all the classic arcade cabinet designers were of the OPINION that the dustwashers should be underneath.
It was arcade ops that put began putting dustwashers on top.
I'm just trying to keep the record straight here, so that the misinformation doesn't spread by being repeated.
And, just to be a butthead, black paint over the sideart was pretty popular with arcade ops at that same time.
Should we all copy that too?
I'm guessing it really kept the dirt from showing on the sides of the cab.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #39 on: September 20, 2007, 11:19:35 pm »
Like a dustwasher is going to keep out liquids. Pfft.
How do you get liquids spilled on your CP anyway?
