Main > Everything Else
Delta-FL
ChadTower:
I'm seeing forum references to a $170/roll price point... that's a 5' x 65.6' roll, so figure 0.55 to 0.60 per sqft once you figure in overlap and waste.
The website says the dimple height is 5/16"... so I figure total height is probably about 6/16"... if you are moving cabs around on it, I'd think 3/4" ply would be a good subfloor? That works out to 1-1/8" + whatever carpet gets put onto it, likely thin to accommodate the cabs. This is at probably 0.55/sqft + cost of plywood (anyone offhand know the cost of 3/4" tongue and groove ply?).
Dricore, on the other hand, specs at 14/16". That's only 1/4" lower. Lowe's lists it at 5.64 per 2x2 panel which is 1.41/sqft. And the Dricore does seem much easier.
shardian:
--- Quote from: ChadTower on September 17, 2007, 03:34:12 pm ---
That isn't bad at all, especially if you are going the laminated wood flooring route.
ChadTower:
--- Quote from: shardian on September 17, 2007, 03:52:20 pm ---That isn't bad at all, especially if you are going the laminated wood flooring route.
That's the big question, and probably what tips one product over the other. I don't know that I want laminated flooring with cabs/pins on it.
Here is one more comparable product. Still need to dig up price.
EDIT: Barricade's site only says it is available at Lowe's in certain states, none of which are anywhere near me. Barricade is out.
ChadTower:
Okay, just got home from Lowe's...
The Drilock there is 5.89 per 2x2 square = 1.67/sqft
Delta-FL is figured to be $170 a roll for about 320 usable sqft at 0.53/sqft. 3/4" tongue and groove OSB subflooring at Lowe's is 13.75 per 4x8 sheet for 0.43/sqft. 0.43/sqft + 0.53/sqft = 0.96/sqft.
So, while these numbers aren't in a vacuum, we're looking at Drilock costing 0.69/sqft more or roughly two thirds more than the Delta-FL and standard subflooring.
That's pretty convincing considering the results will probably be the same.
billf:
What kind of square footage are you guys finishing in the basement? I didn't go this route when I finished my last basement mainly because of the cost - I finished 900 sq. ft. in my previous house - that would come out to nearly a grand using the Delta-FL option. We went with just sealing the concrete floor and then had carpeting and padding installed directly over that. Never had any problems. This was also a newer house (only 3 years old when I finished the basement) with no moisture/dampness problems whatsoever.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
