Main > Main Forum
Ultimarc J-stick screwdriverless switch
gajaman:
I've had a couple of j-sticks since they first came out and they don't seem to have this problem at all.
I wonder if it is because I don't play fighters and therefore am not so hard on the sticks.
Good solution though.
Wade:
I don't play fighters as much as I play classics but I am a bit hard on the sticks I think.
Do you ever switch from 4/8 way? I don't have the problem with them walking if I tighten the screws down a lot. The reason I have the walking problem is because I have to leave the screws too loose if I want to be able to spin the restrictor by hand.
Someone who never switches from 4/8 way or always uses a screwdriver to tighten them down probably won't have the problem.
Wade
Impostor:
Thanks for the pics Wade!
rampy:
There was a discussion about this a little while ago... I'm *pretty* sure Andy bopped in and said that they shouldn't "walk" and you shouldn't need a screwdriver to tighten/loosen 'em...
Let me find that thread before I dig myself any further...
rampy
EDIT I found the thread I was thinking of and it's not talking about what I think it was... i.e. I was wrong!
