Main > Everything Else
PC game backup - How to backup Sims 2 complete! Never reinstall all 11 disks
<< < (3/4) > >>
ahofle:
--- Quote from: spystyle on September 13, 2007, 11:41:52 am ---I guess I'm the only one that finds installing all 11 games unnecessary to do more than once in a lifetime?
You're not the only one.  The windows registry blows -- I miss the days of plain text cfg or ini files in the same directory as the application and no windows crap installed into the system directories.  I used to have my Quake2 folder backed up and when I got a new computer, I just copied it over with no problems.
spystyle:
Those were the good old days!
spystyle:
OK, I am working on it now. It will take a couple hours for WinRAR to zip all those files. After I will test it in "virtual machine" or maybe on a spare computer. I will report my findings.
Below is the "beta version" of my "Sims 2 complete backup" theory.
UPDATE : I have added lines and it will work. Peeps go to "The Hardware Guy" of "MSFN forums"
--- Quote from: spystyle on September 13, 2007, 11:47:02 am ---How to backup The Sims 2 complete with all of your installed expansion packs
backup folders:
C:\Documents and Settings\name\My Documents\EA Games\The Sims 2
(this is a subdirectory in your "My Documents" folder
C:\program files\EA Games\ *.*
(this will vary depending on where you installed your games to)
registry entries:
HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\ *.*
HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\ *.*
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2.exe
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2EP1.exe
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2EP2.exe
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2EP3.exe
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2EP4.exe
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2EP5.exe
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2EP6.exe
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2SP1.exe
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2SP2.exe
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2SP4.exe
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2SP5.exe
To get the registry entires:
click "start" then "run"
type "regedit" (without quotes)
within regedit, "export registry file"
This will save your registry as a text file. Now you can find the file, edit it, and copy/paste the above registry entries to a separate text file.
Make a text file containing the above registry entries, save it as "sims2 complete.reg" or similar.
Note : The registry file you make must start with the following line:
Windows Registry Editor Version 5.00
Otherwise it will not work.
When backing up folders, use Winrar, choose:
"store full paths including drive letters"
Under "split volumes" type "4400m" (without quotes) this will split the backup into files that can fit on DVD-R disks.
When restoring backup all files must be exactly where they used to be - that is why we choose "store full paths including drive letters"
Then double click "sims2 complete.reg" and merge it with your registry
I wonder if it will work....
UPDATE:
Well I'll be... Someone else had the same idea and got it to work:
http://www.msfn.org/board/index.php?showtopic=82007
I found it by Googling "Sims 2" +REG
Previously I was Googling "Sims 2" +backup +complete and had no luck because many n00bs were asking how to backup the folder under "my documents"
There should be a "n00b filter" for Google searches!
I was close, but I had neglected to include the following registry folder:
You can't copy that entire folder, you have to copy one line for each Sims 2 game you have installed.
Groovy, anyway now I will never have to reinstall the 11 Sims 2!!!!!!
I've also learned about the Windows registry. Now I am a smartypants  ;)
Cheers,
Craig
p.s. Below is what my "Sims 2 complete.reg" looks like, but I have installed the games like this:
So you can't just copy my REG, sorry! But I have posted my REG file below so you will know what yours should resemble.
--- Quote from: My Sims 2 complete REG file on September 13, 2007, 11:47:02 am ---Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES]
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2]
"DisplayName"="The Sims 2"
"Installed From"="G:\\"
"Registration"="SOFTWARE\\Electronic Arts\\EA GAMES\\The Sims 2\\ergc"
"CacheSize"="2940524544"
"SwapSize"="0"
"Language"="English UK"
"Locale"="en_uk"
"CD Drive"="G:\\"
"Install Dir"="C:\\games\\THESIM~1\\THESIM~1\\"
"Product GUID"="{6E7DD182-9FC6-4651-0095-2E666CC6AF35}"
"Region"="MX08004261"
"Folder"="C:\\Documents and Settings\\All Users\\Start Menu\\Programs\\GAMES\\The Sims 2\\"
"Patch URL"="http://thesims2.ea.com/update/"
"Suppression Exe"="Sims2.exe"
"EPsInstalled"="Sims2EP1.exe,Sims2EP2.exe,Sims2EP3.exe,Sims2SP1.exe,Sims2SP2.exe,Sims2EP4.exe,Sims2EP5.exe,Sims2SP4.exe,Sims2SP5.exe,Sims2EP6.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2\1.0]
"Language"=dword:00000013
"LanguageName"="English UK"
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2 Bon Voyage]
"DisplayName"="The Sims™ 2 Bon Voyage"
"Registration"="SOFTWARE\\Electronic Arts\\EA GAMES\\The Sims 2 Bon Voyage\\ergc"
"CacheSize"="989150208"
"SwapSize"="0"
"Locale"="en_uk"
"CD Drive"="G:\\"
"Install Dir"="C:\\games\\THESIM~1\\THC8EA~1\\"
"Product GUID"="{F248ADFA-64E0-4b03-8A83-059078BED6A0}"
"Region"="MX"
"Folder"="C:\\Documents and Settings\\All Users\\Start Menu\\Programs\\games\\The Sims™ 2 Bon Voyage\\"
"Suppression Exe"="Sims2SP5.exe,Sims2SP4.exe,Sims2EP5.exe,Sims2EP4.exe,Sims2SP2.exe,Sims2SP1.exe,Sims2EP3.exe,Sims2EP2.exe,Sims2EP1.exe,Sims2.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2 Bon Voyage\1.0]
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2 Celebration Stuff]
"DisplayName"="The Sims™ 2 Celebration! Stuff"
"Registration"="SOFTWARE\\Electronic Arts\\EA GAMES\\The Sims 2 Celebration Stuff\\ergc"
"CacheSize"="381243392"
"SwapSize"="0"
"Locale"="en_uk"
"CD Drive"="G:\\"
"Install Dir"="C:\\games\\THESIM~1\\TH7EF9~1\\"
"Product GUID"="{EAA38532-7AD0-4f78-918A-4F4F02096ECE}"
"Region"="none"
"Folder"="C:\\Documents and Settings\\All Users\\Start Menu\\Programs\\GAMES\\The Sims™ 2 Celebration! Stuff\\"
"Suppression Exe"="Sims2SP2.exe,Sims2SP1.exe,Sims2EP3.exe,Sims2EP2.exe,Sims2EP1.exe,Sims2.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2 Celebration Stuff\1.0]
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2 Family Fun Stuff]
"DisplayName"="The Sims 2 Family Fun Stuff"
"Registration"="SOFTWARE\\Electronic Arts\\EA GAMES\\The Sims 2 Family Fun Stuff\\ergc"
"CacheSize"="307906560"
"SwapSize"="0"
"Language"="English US"
"Locale"="en_us"
"CD Drive"="G:\\"
"Install Dir"="C:\\games\\THESIM~1\\THB261~1\\"
"Product GUID"="{6BDD9CE6-D0A6-478A-BAD3-BA6945E89EB0}"
"Region"="15158"
"Folder"="C:\\Documents and Settings\\All Users\\Start Menu\\Programs\\GAMES\\The Sims 2 Family Fun Stuff\\"
"Suppression Exe"="Sims2EP3.exe,Sims2EP2.exe,Sims2EP1.exe,Sims2.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2 Family Fun Stuff\1.0]
"Language"=dword:00000001
"LanguageName"="English US"
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2 Glamour Life Stuff]
"DisplayName"="The Sims 2 Glamour Life Stuff"
"Registration"="SOFTWARE\\Electronic Arts\\EA GAMES\\The Sims 2 Glamour Life Stuff\\ergc"
"CacheSize"="368110592"
"SwapSize"="0"
"Locale"="en_us"
"CD Drive"="G:\\"
"Install Dir"="C:\\games\\THESIM~1\\TH98E7~1\\"
"Product GUID"="{9CDBC303-3EED-40b0-8E41-A7C65AA96C26}"
"Region"="15208"
"Folder"="C:\\Documents and Settings\\All Users\\Start Menu\\Programs\\GAMES\\The Sims 2 Glamour Life Stuff\\"
"Suppression Exe"="Sims2SP1.exe,Sims2EP3.exe,Sims2EP2.exe,Sims2EP1.exe,Sims2.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2 Glamour Life Stuff\1.0]
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2 H M Fashion Stuff]
"DisplayName"="The Sims™ 2 H&M® Fashion Stuff"
"Registration"="SOFTWARE\\Electronic Arts\\EA GAMES\\The Sims 2 H M Fashion Stuff\\ergc"
"CacheSize"="512181248"
"SwapSize"="0"
"Locale"="en_uk"
"CD Drive"="G:\\"
"Install Dir"="C:\\games\\THESIM~1\\TH14B0~1\\"
"Product GUID"="{84DDE556-43EF-43ed-B2DF-37AF9E5DDD75}"
"Region"="15647"
"Folder"="C:\\Documents and Settings\\All Users\\Start Menu\\Programs\\GAMES\\The Sims™ 2 H&M® Fashion Stuff\\"
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2 H M Fashion Stuff\1.0]
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2 Nightlife]
"DisplayName"="The Sims 2 Nightlife"
"Registration"="SOFTWARE\\Electronic Arts\\EA GAMES\\The Sims 2 Nightlife\\ergc"
"CacheSize"="1361747968"
"SwapSize"="0"
"Locale"="en_us"
"CD Drive"="G:\\"
"Install Dir"="C:\\games\\THESIM~1\\THESIM~3\\"
"Product GUID"="{F7529650-B9DB-481B-0089-A2AC3C2821C1}"
"Region"="14970"
"Folder"="C:\\Documents and Settings\\All Users\\Start Menu\\Programs\\GAMES\\The Sims 2 Nightlife\\"
"Suppression Exe"="Sims2EP1.exe,Sims2.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2 Nightlife\1.0]
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2 Open For Business]
"DisplayName"="The Sims 2 Open For Business"
"Registration"="SOFTWARE\\Electronic Arts\\EA GAMES\\The Sims 2 Open For Business\\ergc"
"CacheSize"="730569728"
"SwapSize"="0"
"Locale"="en_uk"
"CD Drive"="G:\\"
"Install Dir"="C:\\games\\THESIM~1\\OPENFO~1\\"
"Product GUID"="{7B3577F5-1D82-4C9B-008B-69D026FD8BCA}"
"Region"="15157"
"Folder"="C:\\Documents and Settings\\All Users\\Start Menu\\Programs\\GAMES\\The Sims 2 Open For Business\\"
"Suppression Exe"="Sims2EP2.exe,Sims2EP1.exe,Sims2.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2 Open For Business\1.0]
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2 Pets]
"DisplayName"="The Sims 2 Pets"
"Registration"="SOFTWARE\\Electronic Arts\\EA GAMES\\The Sims 2 Pets\\ergc"
"CacheSize"="833653760"
"SwapSize"="0"
"Locale"="en_uk"
"CD Drive"="G:\\"
"Install Dir"="C:\\games\\THESIM~1\\THESIM~4\\"
"Product GUID"="{4817189D-1785-4627-A33C-39FD90919300}"
"Region"="MX08005412"
"Folder"="C:\\Documents and Settings\\All Users\\Start Menu\\Programs\\GAMES\\The Sims 2 Pets\\"
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2 Pets\1.0]
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2 Seasons]
"DisplayName"="The Sims™ 2 Seasons"
"Registration"="SOFTWARE\\Electronic Arts\\EA GAMES\\The Sims 2 Seasons\\ergc"
"CacheSize"="907324416"
"SwapSize"="0"
"Locale"="en_uk"
"CD Drive"="G:\\"
"Install Dir"="C:\\games\\THESIM~1\\TH869A~1\\"
"Product GUID"="{DFEF49D9-FC95-4301-99B9-2FB91C6ABA06}"
"Region"="MX"
"Folder"="C:\\Documents and Settings\\All Users\\Start Menu\\Programs\\GAMES\\The Sims™ 2 Seasons\\"
"Suppression Exe"="Sims2EP4.exe,Sims2SP2.exe,Sims2SP1.exe,Sims2EP3.exe,Sims2EP2.exe,Sims2EP1.exe,Sims2.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2 Seasons\1.0]
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2 University]
"DisplayName"="The Sims 2 University"
"Registration"="SOFTWARE\\Electronic Arts\\EA GAMES\\The Sims 2 University\\ergc"
"CacheSize"="983398400"
"SwapSize"="0"
"Locale"="en_us"
"CD Drive"="G:\\"
"Install Dir"="C:\\games\\THESIM~1\\THESIM~2\\"
"Product GUID"="{8FD3F4BA-A4A6-4380-00A6-CC6853AB2DC2}"
"Region"="14917"
"Folder"="C:\\Documents and Settings\\All Users\\Start Menu\\Programs\\GAMES\\The Sims 2 University\\"
"Suppression Exe"=""
[HKEY_LOCAL_MACHINE\SOFTWARE\EA GAMES\The Sims 2 University\1.0]
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts]
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA CORE]
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA CORE\INSTALLED GAMES]
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA CORE\INSTALLED GAMES\EAGAMES]
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games]
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2]
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2\ergc]
@="374UU5GT1RZ94PDGT5QZ"
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2 Bon Voyage]
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2 Bon Voyage\ergc]
@="1PH92Q1J1111G1111FLT"
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2 Celebration Stuff]
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2 Celebration Stuff\ergc]
@="AS33RLGDBEJK8BEJPRLD"
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2 Family Fun Stuff]
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2 Family Fun Stuff\ergc]
@="5U7FKRK4FDB66KQSLDHZ"
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2 Glamour Life Stuff]
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2 Glamour Life Stuff\ergc]
@="ELUC83CQEWHMKKYVQMR4"
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2 H M Fashion Stuff]
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2 H M Fashion Stuff\ergc]
@="F6B3G84H8UR3D8R2SZ9E"
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2 Nightlife]
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2 Nightlife\ergc]
@="3S7XSVEAGF3ULV7TDBHP"
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2 Open For Business]
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2 Open For Business\ergc]
@="XVSA24UGG34WNG32YRLD"
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2 Pets]
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2 Pets\ergc]
@="G3TKJV6K4TWVQJKK9M9W"
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2 Seasons]
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2 Seasons\ergc]
@="252APPWQX2AZZX225RLD"
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2 University]
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\EA Games\The Sims 2 University\ergc]
@="R44CHRNLVUCT8WAZU1G9"
[HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\Electronic Arts]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2.exe]
"Game Registry"="SOFTWARE\\EA GAMES\\The Sims 2"
"Restart"=dword:00000000
"Installed"=dword:00000001
@="C:\\games\\The Sims 2\\The Sims 2\\TSBin\\Sims2.exe"
"Path"="C:\\games\\The Sims 2\\The Sims 2"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2EP1.exe]
"Game Registry"="SOFTWARE\\EA GAMES\\The Sims 2 University"
@="C:\\games\\The Sims 2\\The Sims 2 University\\TSBin\\Sims2EP1.exe"
"Path"="C:\\games\\The Sims 2\\The Sims 2 University"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2EP2.exe]
"Game Registry"="SOFTWARE\\EA GAMES\\The Sims 2 Nightlife"
@="C:\\games\\The Sims 2\\The Sims 2 Nightlife\\TSBin\\Sims2EP2.exe"
"Path"="C:\\games\\The Sims 2\\The Sims 2 Nightlife"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2EP3.exe]
"Game Registry"="SOFTWARE\\EA GAMES\\The Sims 2 Open For Business"
@="C:\\games\\The Sims 2\\Open For Business\\TSBin\\Sims2EP3.exe"
"Path"="C:\\games\\The Sims 2\\Open For Business"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2EP4.exe]
"Game Registry"="SOFTWARE\\EA GAMES\\The Sims 2 Pets"
@="C:\\games\\The Sims 2\\The Sims 2 Pets\\TSBin\\Sims2EP4.exe"
"Path"="C:\\games\\The Sims 2\\The Sims 2 Pets"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2EP5.exe]
"Game Registry"="SOFTWARE\\EA GAMES\\The Sims 2 Seasons"
@="C:\\games\\The Sims 2\\The Sims 2 Seasons\\TSBin\\Sims2EP5.exe"
"Path"="C:\\games\\The Sims 2\\The Sims 2 Seasons"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2EP6.exe]
"Game Registry"="SOFTWARE\\EA GAMES\\The Sims 2 Bon Voyage"
@="C:\\games\\The Sims 2\\The Sims 2 Bon Voyage\\TSBin\\Sims2EP6.exe"
"Path"="C:\\games\\The Sims 2\\The Sims 2 Bon Voyage"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2SP1.exe]
"Game Registry"="SOFTWARE\\EA GAMES\\The Sims 2 Family Fun Stuff"
@="C:\\games\\The Sims 2\\The Sims 2 Family Fun Stuff\\TSBin\\Sims2SP1.exe"
"Path"="C:\\games\\The Sims 2\\The Sims 2 Family Fun Stuff"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2SP2.exe]
"Game Registry"="SOFTWARE\\EA GAMES\\The Sims 2 Glamour Life Stuff"
@="C:\\games\\The Sims 2\\The Sims 2 Glamour Life Stuff\\TSBin\\Sims2SP2.exe"
"Path"="C:\\games\\The Sims 2\\The Sims 2 Glamour Life Stuff"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2SP4.exe]
"Game Registry"="SOFTWARE\\EA GAMES\\The Sims 2 Celebration Stuff"
@="C:\\games\\The Sims 2\\The Sims 2 Celebration! Stuff\\TSBin\\Sims2SP4.exe"
"Path"="C:\\games\\The Sims 2\\The Sims 2 Celebration! Stuff"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Sims2SP5.exe]
"Game Registry"="SOFTWARE\\EA GAMES\\The Sims 2 H M Fashion Stuff"
@="C:\\games\\The Sims 2\\The Sims 2 H&M Fashion Stuff\\TSBin\\Sims2SP5.exe"
"Path"="C:\\games\\The Sims 2\\The Sims 2 H&M Fashion Stuff"
OK, I tested the above method and REG file on a computer with a fresh OS install, it worked, but the "my documents" backup must go into the current user's "my documents" folder.
For example:
If the backup was made on a computer where the user was named "Administrator", but then transferred to a computer where the user was named "Jamie", the backup will create the folder:
C:\Documents and Settings\Administrator\My Documents\EA Games\The Sims 2
But on the "Jamie" computer there is no user named "Administrator", only a user named "Jamie", so the above folder must be moved to:
C:\Documents and Settings\Jamie\My Documents\EA Games\The Sims 2
Otherwise the game will start but not be able to load the neighborhoods.
RayB:
geez, what you do is you start the first installation, set up the paths and tell the "wimmenz" to sit there and come get you when it's done. Then you show em how the first expansion gets installed and let them do the rest themselves. It's pretty automated. My step daughter could do it herself when she was 12.
spystyle:
That's cruel and unusual punishment!
I wouldn't make my worst enemy sit through all 11 installations! It would be more humane to use a gun.
I guess I just find it so unnecessary and inefficient, as a computer tech I like to make these things easy.
A similar example is "driverpacks" - I used to have to hunt down drivers every time I installed Windows XP/2K/Tiny on a customer's computer, but thanks to "driverpacks" those days are long gone.
A similar example is horse - I used to have to ride a horse to work everyday, but now I have a car and those days of carrying a small shovel and a bag around are long behind me.
Just kidding
But seriously, easy is good! Efficiency is a thing of beauty :) All my Sims 2 installations from now on will be effortless and quick.
Cheers,
Craig
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
