Author Topic: Time Crisis & Porp Cycle - Anyone got them running correctly  (Read 1103 times)
sega_mad
  • Last login:July 09, 2015, 04:03:08 am
« on: September 11, 2007, 04:35:12 pm »
Hi all,
Just wondering if anyone has got either of these games running correctly. I'm running a 3.00Ghz Cpu, but only 512Mb of DDR ram, and was wondering if this might be the issue?
Other than being very slow and "jerky" , when I play Prop Cycle, if I want to turn right because of a mountain out to the left, it will turn left into the mountain!!
Any thoughts.....or are the system 22 games just to demanding for mame!!
Thanks in advance
SGT
  • Last login:April 17, 2023, 08:29:42 pm
Re: Time Crisis & Porp Cycle - Anyone got them running correctly
« Reply #1 on: September 11, 2007, 06:57:46 pm »
I just tried Mame v0.100 and prop cycle is actually playable unlike with the latest Mame.   However I get some stuttering and the FPS is pretty low (29 with no frame skip)  on my P4 3.2 Ghz with 2 gig of ram.   I need to get a video card into this computer which is probably hurting me with its onboard video.
« Last Edit: September 11, 2007, 07:12:08 pm by SGT »
sega_mad
« Reply #2 on: September 11, 2007, 07:51:37 pm »
Thanks SGT,
Might try an older version (.87) and see how that goes. I'm using an arcade VGA
What about Time Crisis?
sega_mad
« Reply #3 on: September 11, 2007, 08:15:46 pm »
SGT,
Would you be kind enough to run through the steps on how to make Mala run these 2 games with mame .87.....Sorry, just not bright enough to work it out, even with all the M2 work!!
Cheers
sega_mad
« Reply #4 on: September 11, 2007, 08:38:24 pm »
Just tried it through the command line (version 0.87) and was playable, but had no sound!
sega_mad
« Reply #5 on: September 11, 2007, 09:12:31 pm »
Turns out the best combination (for me) in mame 1.02 with 1.01 roms, no sound issues, and completly playable...so will just have to re compile it (I'm sure I will have some questions!!) and getting it runing in Mala.
