Author Topic: Arcades with hard drives...?  (Read 1083 times)
Jetto Funk
  • Last login:April 09, 2013, 03:10:28 pm
  • Moo
« on: September 11, 2007, 10:31:49 am »
I have a MACE The dark age cab and it looks like it has a jamma harness but it also has a hard drive.
I've been out of the loop a few years so this is new technology for me. What kind of system is this?
  • Last login:Yesterday at 08:24:26 am
Re: Arcades with hard drives...?
« Reply #1 on: September 11, 2007, 10:42:44 am »
Theres a few different systems that use hard drives. Midway used them in the NFL Blitz/NBA Showtime series and the Killer Instincts as well. In mame they are known as CHD (compressed Heaps of Data, I believe) ,some CHDs are cd images in addition to hard drive images. They both serve the same function a large data rom
Jetto Funk
  • Moo
« Reply #2 on: September 11, 2007, 10:47:14 am »
I see...
So it's not on a Jamma harness, it is its on system.
Would the hard drives be swappable?
These are the games that Mame has a hard time emulating am I correct?
Teebor
  • Last login:June 04, 2009, 12:39:06 pm
  • What does this button do??
« Reply #3 on: September 11, 2007, 10:51:12 am »
It has a hard time emulating some of them, but others like KI2 seem to run ok on powerful machines.
I think Area 51 is a good example of one that doesn't run so well,  I tend to avoid these types of games though
How was your french toast dear?
Smelly and ungrateful
-American Dad
« Reply #4 on: September 11, 2007, 10:54:41 am »
I see...
Ummmmm.....  the games are JAMMA+ compatible, the hard drives plug into the arcade PCBs directly (typically using an IDE cable and power cord) . AFAIK you cant just use any hard drive theres certains brands and types but you can modify a rom (on killer instinct its u8) to accept any drive, including CF cards with IDE adapters.
I can play Killer Instinct  (1 and 2) just fine on my lowly old Dell Optiplex 210L Pentium 4 @ 2.8GHz
Jetto Funk
  • Moo
« Reply #5 on: September 11, 2007, 10:59:19 am »
Last question, sorta strolling off subject but anyways.
I seen a Naomi board on ebay of MVC2, one of my all time fav games, would this work on that cab?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160156133765&indexURL=0&photoDisplayType=2#ebayphotohosting
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #6 on: September 11, 2007, 11:18:20 am »
While NAOMI is not natively JAMMA, there are a couple of adapters out there and that auction appears to include what looks like a Capcom converter (the silver box).
I don't have one (my NAOMI cab has a Sega converter), so I'm not 100% ... perhaps someone with more NAOMI expertise ...Goz ?
Or you could ask the seller.
For more info:
http://www.sega-naomi.com/hardware.htm
Working: Not Enough
Projects: Too Many
Progress: None
« Reply #7 on: September 11, 2007, 11:22:10 am »
Id get clarification from the seller asking if they will include the JAMMA adapter. If it does come included then it should work but Im sure minor rewiring will need to be done.  Actually if memory serves me right, mace used 4 buttons kinda spread out and MvC2 use 2 rows of 2 (2/3rds of a SF layout) so you might have some control panel patching to do, or simply adjust to the layout. I dont know if your MACE cab is dedicated or anything, I know trying to play Street Fighter II on my MKII cab was hilarious
« Last Edit: September 11, 2007, 11:24:12 am by Malenko »
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
« Reply #8 on: September 11, 2007, 10:49:53 pm »
I have MVC2, and I have some arcade knowledge so I will try to answer your questions.
 1) I don't think your MACE cab would work because you only have 5 buttons while MVC2 needs 6.  Now before anyone jumps on my case, I'm assuming that you have not made any modifications to your cab.
 2) If you have the layout as the typical SF layout, it still won't work because you need a kick harness to handle the kick buttons on a typical SF layout.  You'll need a Capcom harness to plug into the silver box.
 3) If you have the layout, and the kick harness, you can unplug your Jamma harness off the MACE board and connect it (as well as your kick harness) to the silver box shown in the auction.
My $.02
Jetto Funk
  • Moo
« Reply #9 on: September 12, 2007, 08:50:53 am »
I think I'll just save my pennies and buy a dedicated MVC2 one day :)
Thanks for the input everyone!
