Author Topic: How do I hook up aTron spinner to an Optipac?  (Read 2334 times)
Paul Olson
  • Last login:May 07, 2024, 03:19:08 pm
    • Paul's Arcade
« on: September 11, 2007, 12:19:04 am »
I did a search, but didn't come up with anything. Does anyone know how to connect an original Tron spinner to an Optipac? There are 10 wires on the spinner and I don't know what to do with them all.
Thanks,
Paul
ArtMAME
  • Last login:August 05, 2020, 12:59:17 pm
  • Hey where the ARCADE MACHINES at???
    • Art's Arcade Lab
Re: How do I hook up aTron spinner to an Optipac?
« Reply #1 on: September 11, 2007, 12:44:09 am »
I believe the optic board for the Tron is proprietary so it is not plug and play compliant for an Optipac.    I have seen one hack where you hack the traces on the Tron optic board and hook them up directly to an encoder, but this may be somewhat tricky.
I removed the Tron optic board and ended up using a mouse PCB mounted on a piece of wood that just happened to be the perfect dimensions to screw on to the bracket where the original Tron optic board was.
I can't remember what mouse it was, but it was perfect, and it works great.  I will take a picture of it when I get home, which won't be till Thursday or Friday... I am on the road right now working... in scenic Newberry, SC... testing Komatsu bulldozers for regulatory compliance...
"Klaatu. .. Verada. ...... Necktie...Nectar...Nickel..."
BobA
  • What Me Worry?
« Reply #2 on: September 11, 2007, 12:58:32 am »
You could replace the optic board with one of the GP ones for sale in the buy/sell area.  You would then be left with leads to the switches for the up and down function but a standard 4 pin interface to the optic board.
Hoopz
  • Last login:February 09, 2024, 02:36:26 pm
  • Intellivision Rocks!
« Reply #3 on: September 11, 2007, 06:23:39 am »
gl.tter had posted how he hooked his up and here is the thread.
http://forum.arcadecontrols.com/index.php?topic=41803.0
It used to link to his website where it showed the details.  I can't find them on there now though.  :dunno   You could try contacting him but he hasn't logged in here in awhile.  His email address is on his website though.
I had tried it without success.  That could be because I can't solder well.  I ended up buying a board from Fixumdude in the B/S/T section that was great.  Plug and play, very well made, good instructions, and inexpensive.
http://forum.arcadecontrols.com/index.php?topic=48855.0
That's what I would do.  YMMV
Good luck!
« Last Edit: September 11, 2007, 06:25:18 am by HooPZ »
Clu
  • Last login:January 10, 2013, 12:34:22 am
  • Watch it, sucker.
« Reply #4 on: September 11, 2007, 03:17:06 pm »
I tried that hack on two Tron boards and it worked great.  I originally just had a Happ board mounted on the spinner, but I thought I'd give it a try and use the original Tron optic board if possible.
Don't have an optipac though.
Paul Olson
    • Paul's Arcade
« Reply #5 on: September 11, 2007, 06:54:08 pm »
Thanks for the info everyone.
Clu - Do you still have the instructions for the hack? I will try to contact gl.tter, but his site looks like he may have moved on from the arcade stuff.
Thanks,
Paul
Hoopz
« Reply #6 on: September 11, 2007, 09:19:10 pm »
Thanks,
Paul
He's writing the code for the light stuff for mame.  I'd bet he would email you back if you asked for it.  I'll go through a box o' stuff to see if I have it still.  I know I printed it when I was trying to get it to work.
Clu
  • Watch it, sucker.
« Reply #7 on: September 11, 2007, 09:23:16 pm »
Here's the link to the original instructions - http://gl.tter.org/spinnerhack/ and I posted a couple pics of my hack here - http://www.fortunecity.com/rainbow/snowwhite/311/arcade/
I used a drill press and tiny bit to severe the traces instead of trying to cut them, and also soldered onto the traces as opposed to the led/pickups.  Seemed to have a bit more room that way.  I also just soldered the wires onto a 4 pin connector for easier hook-up to a standard harness instead of trying to mount it as gl.tter did.  Good luck if you try it. ;)
Hoopz
« Reply #8 on: September 11, 2007, 09:29:22 pm »
Nice job posting this!   :applaud:
I should have tried your way.  I don't know if my board was bad to start with or if I messed it up.  Just wasn't good enough to get it done.
Paul Olson
    • Paul's Arcade
« Reply #9 on: September 12, 2007, 02:50:17 am »
Thanks for posting the links!  Hopefully I will have time to try this sometime this week.  I'll post with results after I try it.
Thanks,
Paul
Chunce DeLeone
  • Last login:August 16, 2012, 02:58:11 pm
« Reply #10 on: September 13, 2007, 12:24:19 pm »
I have a tron Spinner and took an optic board from a trackball which I used on it.   Works great.
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #11 on: September 13, 2007, 05:18:05 pm »
Here you go.  One of these days I'll do mine  :-[
EDIT:
Bah!  Double post.  I suppose I should read the above posts first.
« Last Edit: September 13, 2007, 05:22:34 pm by Nannuu »
Next I'll be on fries, and that's when the big money starts rolling in.
Paul Olson
    • Paul's Arcade
« Reply #12 on: September 15, 2007, 05:59:10 pm »
No luck so far. I can see the LEDs on my camera phone, but not working at all. I have no way of knowing if the board worked before I messed with it, or if I broke it. I will have to mess with it more later.  I hooked up my oscar spinner and I am having a good time playing tron. After 2 days I can usually score about 40,000, so I am starting to get a little better.  :)  It has been a long time!
Thanks to everyone who helped on this
Clu
  • Watch it, sucker.
« Reply #13 on: September 15, 2007, 07:44:44 pm »
Did you set your optipac to active high?
