Main > Main Forum
Help with CP design
XyloSesame:
Thanks for your experience, severdhed. Your issues with Frankenpanel usability mimic my fears. Button interference and reach/depth of panel.
Trouble is, I'm looking forward to both spinner and trackball games.
After I've spent some time with the CP, I might just end up doing a revised panel like you and eliminate unused controls...
severdhed:
thats really all you can do. build it, use it, revise it, repeat. i am on my 5th panel right now, and I am finally pretty happy with the layout. I still have some craftsmanship issues i need to work out, but the spacing and feel of everything is pretty good. I don't know if you are planning on a control panel overlay, but may i suggest building a test panel so see how everything feels, before you go to the expense of printing out an overlay only to find out you want to change something. a heavy cardboard box, or cheap piece of wood or paneling makes a nice mock control panel to test spacing and layout. i think that the next time i redo my panel, it will be to add artwork, not to move anythign around, but it took me 5 revisions to get to that point. i'm glad i didnt print out overlays for all of them
RobotronNut:
a couple of things:
(1) my 8-ways are 22.5" apart, and i play a lot of robotron, and i love the spacing.
(2) if you care about 4-way games, don't lose the dedicated 4-way. you need the diamond-shaped restriction.
(3) the asteriods-type games work fine with your 2 hands separated, so the two 7-button "fighter groups" you have will be perfect for asteroids. will work much better than trying to use a joystick.
(4) specific joystick models can make a huge difference in your scores in some games. i'm sure you've seen the endless discussions here about joysticks. on a tight budget, the following work very well: 4-way - ultimarc J-stik, 8-way - happ super.
cthauber:
You have a very similar design to what I am in the process of building.
I went with the Ultra 360 sticks to have the analog ability (mainly for N64 games). I can also then use the 4 central buttons as the N64 "C" buttons.
Within Mame, the 4 central buttons will be the same as P1 buttons 1-4, so I will have a nice layout for HyperSports, as well as a nice close button for spinner games.
The cutouts that are set about 4.5" from the edge are 2" wide, and the inner face is where a couple of flipper buttons will be located for pinball.
I figured the total width of 33" is just too wide for a comfortable pinball feel (most standard pinball machines are around 22" wide).
Anyways, I will hopefully be starting my cutting in the next few days. Looking forward to getting it all done :)
Chris
Dire Radiant:
The slot idea for the pinball buttons really isn't doing it for me. Have you thought of a stepped design without the two bottom corner pieces?
