Main > Everything Else
BYO Free Energy Gravity Wheel Machine
SavannahLion:
--- Quote from: RayB on September 10, 2007, 12:39:19 pm ---Well the main point the old man makes IS interesting, and that's the part he sums up on the whiteboard. By taking the balls back up closer to the center of the wheel, there is always more weight on the outer opposite side to keep the wheel going. ...
That had me stumped for a little while too. Even if you remove all other sources of energy loss, such as friction, intuitively, I know it can't work the way he describes it, I just couldn't pick out what.
Then it dawned on me. The distance he needs to pull up the balls near to the center is farther than the distance to drop away from the center. It really needs diagrams to prove the point, but I'll try my best with words. Truly accurate math involve circular functions, which happen to be one of my weaker math fields. If I can figure this out without doing the necessary math, what's that to say about his intelligence?
To make the point as succinct as possible, take a pencil or ruler or some other appropriately long narrow object (a penis won't work) and figure out the physical center (not balanced center) and seesaw it back and forth around this center. Note the distance each end travels. as you seesaw the pencil.
Now move the "center point" to about three quarters of the way to either side. Now seesaw it back and forth around this center and note the distance each end moves.
That's the problem with his logic. If we assume a ratio of 2:1, at least two balls have to travel down the far side of the wheel in order to carry up one ball on the near side the required distance. (His ratio isn't exactly 2:1. It's probably more like 1.2:1.) This is exactly why two balls sometimes gets trapped in the same cup on the lifting side. Even if he figures out the exact number of cups on both the inner and outer part of the wheel and their exact positioning to always ensure one ball per cup, he can't get away from the fact that it requires more balls going down to bring up a ball the same distance. Eventually, he'll run out of balls.
ChadTower:
Please, please, please stop talking about this guy's balls in such detail.
kthx.
Ed_McCarron:
--- Quote from: ChadTower on September 10, 2007, 12:43:05 pm ---Which I'm sure would work fairly well in a frictionless environment.
Not sure whether to make a joke about physics class or Jenna Jameson. Both had frictionless environments.
ChadTower:
When in doubt move towards Jenna Jameson. There is light at the end of her tunnel.
SavannahLion:
--- Quote from: ChadTower on September 10, 2007, 02:15:55 pm ---
kthx.
Trust me, I tried really hard not to think about his balls while writing that.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
