Main > Main Forum
New encoder advice please
Pages: << < (2/2)
SavannahLion:
--- Quote from: Malenko on September 06, 2007, 03:47:53 pm ---both Randy AND Andy rocks off my socks off
That's disgusting.
u_rebelscum:
--- Quote from: Marky_1979 on September 05, 2007, 08:13:45 pm ---Hi guys I bought a hagstrom ke 72-t encoder...
Do you use the TB feature?  Are you going to leave that part as is if you do use it?
If you are going to replace the hagstrom totally, and want the TB feature on the same encoder, get the minipac.  Otherwise you'll need a keyboard encoder + TB encoder.
If you're not using the TB feature, or are keeping the hagstrom for that, then like others said.
Chunce DeLeone:
I would stick with the KE72,  if something is broken on it, try to send it to Hagstrom,  I had no problem when i sent mine in after owning it for 7 years,  they fixed it free of charge and updated the chip,  KE72 is the Cadillac of encoders!!!!! :soapbox:
xmenxmen:
--- Quote from: u_rebelscum on September 06, 2007, 06:26:35 pm ---
Please note that you will need a 2nd encoder if you get the minipac as it doesn't have enough input for 4 player.  keywiz/gpwiz are great as a 2nd encoder.
Marky_1979:
The trackerball part works perfectly so was thinking of keeping it set up to the hagstrom my only issue about sending the encoder back for repair is the fact I live in the UK cant find my receipt and feel it might be a real hassle to sort out. I think I will look at these other encoders Iv down scaled my arcade controls so it will only be a 2 player cabinet now with 6 buttons each and some admin buttons
Pages: << < (2/2)
Go to full version
