Main > Everything Else
Need help with a Photoshop droplet
<< < (2/2)
patrickl:
If you want to fit images in a certain maximum you should use Automate -> Fit image. You can restrain both the vertical and the horizontal size.
On the other hand, usually I restrict portrait pictures to a smaller size since otherwise they would not fit on screen. For instance in landscape I would make it be max 1024 wide (1024x768), but portrait would be 768 tall at maximum (576x768). So I would just scale it all at 768 high.
BTW don't forget to sharpen the images during or after resizing. They tend to lose sharpness when resized.
mpm32:
Maybe Irfanview?
DrumAnBass:
Yah I used to use Photoshop for those web albums, but ran into some of those issues myself.
I would recommend JAlbum - http://jalbum.net/ Easy to use; lots of skins available and works really well!
clanggedin:
I used to use a Photoshop (Imageready) droplet to batch resize and optimize images for the web. I found the Irfanview much quicker and better to use.
xmenxmen:
Or ditch your web gallery and use Gallery or Gallery 2 for your web gallery.
http://gallery.menalto.com/
It will do all you want above plus more.
Navigation
[0] Message Index
[*] Previous page
Go to full version
