Main > Everything Else
Air Hogs Apache Havoc Helicopter
<< < (3/5) > >>
boykster:
interesting, your trim adjustment or the rotor must be off - mine holds steady when trimmed.....
yep, fun toys!
patrickl:
If it keeps spinning even when trimmed to the max, it might be that the tail rotor is damaged. If the tail rotor doesn't look "right", you can try bending it straight or replace it with the spare.
Hawk Daddy:
Hey will you see it the air hogs one can lift a 9v battery, i have some wireless cams and that would looks really cool to have flying around.
Hawk
KenToad:
--- Quote from: Hawk Daddy on September 05, 2007, 04:16:43 am ---Hey will you see it the air hogs one can lift a 9v battery, i have some wireless cams and that would looks really cool to have flying around.
Hawk
Those copters can barely lift very small items.  Even just the pin part of a tack completely changes the way they fly, so I'm fairly certain they won't lift a 9v battery.
As for the rotor issues, I have put a new blade on and, even trimmed to the max, it still won't stop spinning until a few seconds after I hold right on the controller.  I think the rear motor must have been damaged in a crash, but I don't know.
Thanks for the advice.
patrickl:
Or maybe the tail boom is twisted. I had that too. I had to straigthen the tail to get it to work properly.
Like I said my 4 year old played with it too and he tended to fly into everything. I was impressed how much abuse that little chopper could take actually. Now and then I had to straighten some things, but it kept going.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
